Gauges
Gauges
1991 Accord sedan. tach, speedo, fuel/temp gauges not working. Odometer and tripometer are working. Fuel gauge rises to full and stays at fuel. Temp gauge rises up to max on startup and stays.
MM Gruppe B
Re: Gauges
If the cluster has been removed or replaced the wires or connectors may have not have been seated properly.
An open in the Fuel circuit would cause the gauge to peg at fuel. I think Temp is the same as well. Thermo(temp) sensor is located below the distributor, verify that the wire going to it is still connected and not just floating or grounding out on the engine.
Two2ManyHondas
11-01-2013 09:29 PM
sidewayz
09-22-2013 09:28 AM
teh_pledge
03-20-2011 01:39 PM
