Front end noise?
I have a 2000 accord that is making a loud roar somewhere from the front end. It only does it when im driving, it gets louder the faster I go. It's not knocking on turns it just makes a deep grinding noise. I know it's not the engine or tranny but I'm thinking cv joints. Just wanted to see if anyone else has had this problem. Thanks for any help.
Re: Front end noise?
Wheel bearing? Does the noise change at all when you turn left/right?
it gets a lil quieter. How can I tell the difference between the bearings and the cv joints?
CV joints usually pop when you turn your will while rolling. If you turn left and you hear a popping, it's your right axle. If you turn right and you hear popping, it's your left axle.
Are your lug nuts on tight? |
