F22a1 swap with f22b2 WHAT DO I NEED HELP
Old 07-18-2019, 09:04 PM
Fred Hurt's Avatar
Default F22a1 swap with f22b2 WHAT DO I NEED HELP
I know its a down grade but I got it cheap. will the intake maniford from the 93 honda accord work? .the gaskets look different. Please help thanks.
Old 07-18-2019, 10:01 PM
Premium Member
Aradin's Avatar
Default Re: F22a1 swap with f22b2 WHAT DO I NEED HELP
I'm assuming you're trying to put an F22A into a 94-97 Accord from the little info you posted. Caps aren't going to get you a quicker or better response. A little searching would have told you that the F22A and F22B series intake and exhaust manifolds are completely different. This is because the head ports are different and not compatible with each other. To swap the F22A into your car you would need to use the F22A intake and exhaust manifold. There will be some fiddling to get the wiring and everything to work and I believe your exhaust will need to be modified. Honestly would be easier to just swap your original F22B2 head onto the F22A block and reuse your factory manifolds, etc. That's assuming the head isn't trashed. Also beware that there is a small water port on front center part of the F22B2 head that will need to be tapped and plugged if used on an F22A block. Other than that it's a direct fit.
Old 07-18-2019, 10:03 PM
Fred Hurt's Avatar
No putting f22b2 in my 93
Old 07-18-2019, 10:07 PM
Fred Hurt's Avatar
So dont use the f22a1 intake on the f22b2
Old 07-18-2019, 10:32 PM
Premium Member
Aradin's Avatar
It would basically be the opposite of what I originally said then. You would need to use the F22B2 manifolds as they are not interchangeable. Again, there will be some modifications required to get the F22B2 to work in your vehicle. Wiring, hoses and lines, exhaust will likely need to be modified, etc. It will fit as the blocks are basically identical but there is some work involved. If your F22A head isn't trashed you could swap it onto the F22B2 bottom end and save yourself a lot of trouble.
Old 07-18-2019, 10:35 PM
Fred Hurt's Avatar
F22a1 is trash. Ok what do I do about the fuel line f22a1 on lift side f22b2 on right side . do they make longer fuel lines
Old 07-19-2019, 01:19 PM
Premium Member
Aradin's Avatar
You may try using your original fuel rail off of the F22A1 intake manifold.
Old 07-20-2019, 12:38 AM
Fred Hurt's Avatar
Will not work .thanks
SlimNubster
07-31-2009 06:24 AM
Phils
06-07-2007 05:41 PM
SKDRCR
12-01-2006 05:58 AM
na14yu
08-17-2004 10:55 AM
HaTcH_BmX
11
11-04-2003 04:08 PM
Quick Reply: F22a1 swap with f22b2 WHAT DO I NEED HELP
