Pulling out shift cables from 94 Accord transmission??
I removed the all the cotter pins but the shift cable still is attached to manual transmission on my 94 Accord LX. Is there anything else I need 2 remove??
It seems to be attached to like a bracket of some sort.
Re: Pulling out shift cables from 94 Accord transmission??
yup theres a bracket thats bolted onto the tranny that the cables are clipped to. if' your trying to drop the tranny you can either A: pull the clips with plyers or vice grip, or B: Unbolt the bracket from the tranny. The bolts are all under neath the lower radiator hose and wire harness so you'll have to kinda look for them. there's 3.
I have the shop manual with the exact picture that has been posted on here. But I cant seem to find where that cable bracket is. It looks like the shift cables are behind the block like under where my intake hose used to be, but im not sure. Can anyone help? Thanks in advance.
It is located on the top of the transmission pretty much directly under the thermostat housing/to the left of the distributor and down. You will need to remove the intake tube in order to get at it.
BoostedH23Accord
03-06-2007 12:11 AM
