Alternator Belt
Alternator Belt
I need to tighten my alternator belt, its driving me crazy... i heard its pretty easy, im not sure how you do it tho. How do you do it?
Re: Alternator Belt (GReddy212)
Well, on your 82 accord hatchback with the turbo V-12 Cummins diesel engine you'll need to loosen the pivot point bolt, then the "tension stay" bolt then use a big pry bar to get more tension. Tighten the tension stay bolt and then tighten the pivot bolt.
Re: Alternator Belt (eauto)
i usually tighten mines, not too tight, but until i cant turn the belt past 90 degrees or see the ribs while looking straight down at it .
in some manuals, it will give you a torque specification for the adjusting bolt or it will tell you to measure the belt deflection by applying some force down on the belt with a ruler and make sure its around 3/8 to 1/2 inches .
Re: Alternator Belt (redxalien)
my **** is sqeaks when it wet.
what are the torque specs for replacing belts on a 97 accord?
Is the alternator belt on the outter part or nearest to the timing belt? i'm guessing the outter belt is the ac belt
Re: Alternator Belt (businessmanph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by businessmanph »</TD></TR><TR><TD CLASS="quote">
Is the alternator belt on the outter part or nearest to the timing belt? i'm guessing the outter belt is the ac belt</TD></TR></TABLE>
This truely is not intended as an insult.....if you can't figure that out you might want to pay a mechanic to do it. It is most likely the inner belt meaning you will have to pull the power steering and air belts first.
Re: Alternator Belt (alotawatts)
Yeah I agree, no offense but if you can't find the alternator and it's belt, then honestly I dunno if you should be messing with them - I would hate for that belt to snap or fall off on the highway and you'd be stranded.
Fo-Do Fanatic
04-07-2010 03:59 AM
519[H]Si
05-25-2004 09:25 PM
