Accord 2001 leaking issues
I noticed that my wife's car was leaking and i opened the hood and saw that there was a trail of fluid coming from the top rad hose... Right where the hose connects so i tighten the clamp... As am cleaning up the mess it made in the engine bay i also notice that my power steering pump is dirty and the alternator belt has some discoloration and i turn my car on and it seems like fluid is comin from the top connection on my pump could this be caused because i used prestone power steering fluid its been over a year that i added some from the low to fill line could i just be that o ring .... Also my vtec soleiond leaks until the car gets hot i just want to make sure i order all the right parts.
Re: Accord 2001 leaking issues
I would start with new o-rings (vtec and ps) and see what you have from there.
Also, not sure how much coolant was lost, you might want to bleed the cooling system to be sure you get all of the air out.
murrellington
05-08-2014 03:30 PM
