drive axles? tranny problems? or misfiring???????//
i bought a 94 ex auto tranny with a 147,000 i really have no previous knowledge on the car or its maintainace, the car might have several seperate problems but here is what its doing, first when i turn sharp from a stop i hear a clicking sound which i figured was the drive axle on the right side then it started doing it when i turn left sometimes , also at the same time when i drive the car say when im at a light or stop sign and accelerate normal like say a older person the car stutters like its either missing or something but if you accelerate it more it runs perfect its just when your accelerating at low rpms even when im going say 40mph and barley touch the gas to continue going at the speed it does it , im lost like a mofo
Re: drive axles? tranny problems? or misfiring???????//
I don't think it's a tranny problem... I'm not some pro, but I could tell you what to check for.
As for the clicking, I'm darn sure it is the axles. See if the boot is torn open. I suggest getting that fixed IMMEDIATELY. As for the stuttering, would you say it was misfiring or? I'm guessing, IDK but i think that the axle might be so bad that it kinda jams up therefore making your car stutter. I need more info on this. (Throwing some random theory, LOL) |
Originally Posted by jsteezy1290
(Post 37131768)
Most likely the really bad one will have a broken / split boot seal associated with it. The easiest avenue on this is to install a remanufactured axle assembly. If you see any indications of the opposite side's boot seal cracking (in the creases), it will be worth your time to have that boot replaced. As long as the seal didn't break open; you can replace just the boot seal. Is there a "check engine" lamp shining on the dash face? If there is not, you could be dealing with carbon buildup in the egr ports. They could cause a stuttering sensation under light aceleration between 1800 and 2100 rpm. Refer: http://home.comcast.net/~em-engineering/T2T013.pdf P |
im hoping that it just needs a tune up, im going to replace plugs wires rotor and cap but honestly it all looks fairly new so who knows, im also going to drain the trans oil and put some new in it. the carbon build up on the egr ports is a good idea if i do all that and it still does it i will prolly check the ports
(Post 37136324)
You've got the info you need. Let us know how the Accord turned out. That may have been a clue [quote] "but honestly it all looks fairly new" [quote], hopefully this work wasn't performed for just this reason..... P |
well i did the tune up and noticed the distributor cap was cracked and so was the button inside so i thought i had her figured out lol, well i ran great for about 10 miles then started doing it again so i took the cap back off and button and noticed the part with all the wires to it is also cracked so im thinkin thats the problem but do i have to buy a whole distributor or can i buy just that part, by the way i replaced the axles too and have determined that this is a spark problem for sure
man this site is not what it use to be a couple years ago, you use to post something and within minutes there was a reply, where did everyone go??
(Post 37158953)
The rest left because of the incessant whinning....... That component is refered to as either the Ignition module or the Ignitor module. It is available seperately. P |
yes i know there 169 i think im gonna try to pick up a used distributor and get it
well i replaced the plugs wires cap and rotor and distributor, please tell me what is causing this low rpm miss, it doesnt miss at idle on while driving at low rpm
bump!!!!!!!! before i take it to a honda dealer and get stroked,,,
(Post 37235915)
timing
chaulk another one up to the egr ports being clogged, i was bored today and decided to check and see if this was the case , 3 of the 4 ports were completly clogged so i cleaned em out and the car runs like a dream ...
