doing a timing belt question
GDD Member
Re: doing a timing belt question
Torch? Someone suggested a torch? Wow.
Sometimes the bolts are tight, sometimes they aren't. These cars are so old that the belts have already been changed anywhere from 1-3 times in the past and you never know how tight the last guy put it on, so I've had a couple that came off with a 3/8 impact before.
you're kidding right? i heard it doesn't work on most honda motors. i hear that would only tighten the bolt. but that's what i read.
I would not suggest using your starter. If you know any mechanic that uses this method do not take your car back to him....EVER!
I had mine stuck on there and it wouldn't even budge with a 1/2 drive impact rated at 400 lbf-ft. It has something to do with constant pressure vs the hammer action of an impact. If your pulley bolt is on there good and tight it will require a constant pressure to crack/break the bolt free vs hammering on it.
I used a small breaker bar with the hex pulley socket on it. Rotated it so that it was braced on a block of wood on the garage floor. Then I proceeded to use a 6' breaker bar (2" sched 40 pipe) on the end of my 1/2" drive ratchet on the pulley bolt itself. I pushed down on it with most of my weight and snap it broke free just like a regular bolt. I did use a bit of heat but that's only because I am replacing my crank pulley (Hopefully )
say if i weighed 300lbs and i step on the breaker bar vs a 500lb impact, would 300lb be better since it is constant?
In this case Yes. But you have to remember that your pushing more than your weight. @ 300 lb & using a 6' breaker bar/extension you would be exerting approximately 1800 lbf-ft of constant tq.
GDD Member
In regards to the starter method, it's a method which has been used for a long time by a lot of people, but not on Hondas. Honda motors spin counter clockwise and the bolt is a right handed thread, so if you use the starter, the bolt will be driven in tighter.
JDM_SOHC
27
09-28-2009 09:05 AM
