DIY - Rotor Over Hub Conversion
Old 05-06-2018, 07:00 AM
  #176
Default Re: DIY - Rotor Over Hub Conversion
Originally Posted by dwllama View Post
The Accord and the CL use the same bearing. Only the hub is different. Literally, the OE part numbers are identical for the bearings. Some aftermarket suppliers incorrectly list it as a hub assembly bearing because it has the flanges. It's just a bearing. The hub is the part with the wheel studs and a shaft that fits into the bearing.
So in other words you can just straight up use the assemblies for the CL. You don't have to swap bearings off them at all.
Thanks for the clarification.
EscCtrl is offline
Old 05-06-2018, 08:33 AM
  #177
JimL's Avatar
$50 on PP to whoever is first to add link(s) to some place you can buy 98/99 Acura CL 4 bolt hubs like the ones pictured in the first post.
I can only find hubs like these
https://www.ebay.com/itm/Dorman-950-...y/192393196133
JimL is offline
Old 05-06-2018, 03:06 PM
  #178
Originally Posted by JimL View Post
Thanks! As far as I can see Acuraoemparts does noe have the hub available anymore. But if I understand correctly I can get the assemblies from Ebay and then swap out the bearings with new Accord bearings
it's 24 not 3
holmesnmanny is offline
Old 05-06-2018, 03:37 PM
  #179
angrysmileyface's Avatar
Car-part.com
angrysmileyface is online now
Old 05-06-2018, 04:01 PM
  #180
this is for those don't have eyes to see
Old 05-07-2018, 08:46 AM
  #181
car-part.com Fill out the info, you're looking for a spindle for a 98-99 Acura CL and select your zip code. Remove hub and buy new bearing if necessary.
Old 05-07-2018, 11:00 AM
  #182
JimL's Avatar
How the .... did I miss that. I've spent hours browsing for that hub and completely missed there were two sets in that image.
Extremely helpful, thanks!
JimL is offline
Old 05-08-2018, 02:13 AM
  #183
no problem at all, bud ... the very first time I looked at the honda diagrams I missed em too
I have done the conversion but I am gonna be in the market for a new hub assembly myself and as you can see the ebay ones are considerably cheaper, in fact, they are the only ones I have found on ebay
if you get the ebay one, let me know how it works out and if the hub is true or not after some miles of driving with new rotors
the good thing about the ebay ones is that it has the bearing already pressed onto it so you get the bearing too and it just bolts onto your existing knuckle and the rotor goes right on top, obviously
given that the bearing they use is NTN, I'm sure the hub is going to be a quality product as well
so if you can let me know how it turns out before i make my purchase i'd appreciate it
Old 05-15-2019, 09:39 PM
  #184
Originally Posted by TOP END MS View Post
You forgot to mention which hub you got. But im assuming the CL '98?
Originally Posted by JDM_DC4_Fanatic View Post
I get shop discount, so each hub cost me $62 and $40 for the bearings. CL Rotors were $40 for both and front pads were $50 for Wagner Thermo quiets. Bringing my total to $194. Now, you may end up paying more for it, everybody gets diffrent prices.
Also, You can re-use your stock bracke calipers, brackets, pads and wheel bearings, However, you can not press out the hub from the bearing without taking the outer race out. So, if you do this swap, you MUST get new wheel bearings. Accord and 98 2.3CL are the same.
I'm reaching for the 98 cl hubs and can't find them in any parts store can anyone help me ?
Locate them I'm in l as Vegas nv.
Escamilla_o08 is offline
Old 05-16-2019, 09:29 AM
  #185
Default Re: DIY - Rotor Over Hub Conversion - NOW COMPLETE - 56K take a snooze
I just finished my Rotor-Over-Hub Conversion today, and I took pics along the way, so I figured I would share it with you guys, and maybe help some people out. I also noted that in the Guide to Basic Accords, the R-O-H conversion link is actually from accordingly done, which I think is an insult to us H-T guys. We can have our own DIY's.
Before I begin the process, I will list out the tools and parts you need to get the job done.
Tools:
Proper sized socket to remove lug nuts (usually 19mm, unless aftermarket)
10mm 12 point socket - Wheel bearing bolts
17mm Socket - Caliper bolts, ball joints, tie rod end, caliper bracket bolts
10mm 6 point socket - upper ball joint nut cover, ABS wire bracket bolts, Brake line bracket bolts
14mm Socket - Brake line to caliper bolt (optional)
Torque wrench - same size drive as sockets
36mm socket - Axel nut
48Oz Hammer - Separate ball joints
pliers - To remove cotter pins
Parts:
1998 Acura 2.3CL Front Hubs OEM part # - 44600-YS8-A00
1998 Acura 2.3CL Front Rotors OEM Part # - 45251-S84-A01
1990-1998 Accord Front wheel bearing OEM Part # - 44200-SM1-008
1990-1998 Accord Front brake pads OEM Part # - 45022-SY8-A01
New cotter pins
Step 1:
Raise and support the front of the vehicle safely on jack stands and remove the front wheels.
Attachment 492570
Step 2:
The first thing I like to do is loosen the axel nut. You will need a 36mm socket, and an Impact gun(preferred) or a breaker bar, and a long pipe for extra leverage.
Attachment 492571
Attachment 492572
Step 3:
using pliers, remove the cotter pins in the tie rod and lower ball joint. Using a 17mm socket or wrench (socket preferred), loosen the castle nuts on the lower ball joint, and tie rod end. Once he castle nuts are loose, whack the knuckle with a hammer perpendicular to the studs. Note* Ball joints and tie rods are taper fit, always hit the knuckle, not the stud itself or you will ruin the threads. Once the tie rod end is loose, remove the castle nut, and remove the tie rod from the knuckle assembly. Leave the lower ball joint loose, but in place for the time being.
Attachment 492573
Attachment 492574
Attachment 492575
Attachment 492576
Attachment 492577
Attachment 492578
Attachment 492579
Step 4:
Using the 10mm 6 point socket, remove the upper ball joint cover (2 bolts), Brake line bracket (2 bolts) and if applicable, the ABS sensor wire bracket (2 bolts)
Attachment 492580
Step 5:
With the upper ball joint cover removed, remove the cotter pin and loosen the castle nut like on the lower ball joint, and whack it free, but still leave it loosely in place.
Attachment 492581
Attachment 492582
Attachment 492583
Attachment 492584
Attachment 492585
Step 6:
You can either unbolt the caliper and caliper bracket assembly, and swing it aside, OR, you can undo the brake line bolt and leave the bracket and caliper on the knuckle. I recommend to simply remove the caliper and bracket, and swing it aside. Note* If you do decide to unbolt the brake line, be sure to bleed the brakes when it is reattached.
Attachment 492586
Attachment 492587
Attachment 492588
Attachment 492589
Attachment 492590
Attachment 492591
Attachment 492592
Step 7:
Remove the castle nut on the upper ball joint, and separate the top of the knuckle from the upper control arm. Remove the axel nut and tilt the knuckle forward and remove the axel from the bearing/hub assembly. Remove the castle nut on the lower ball joint, and lift the knuckle out.
Attachment 492593
Attachment 492594
Attachment 492595
Step 8:
Using the 10mm 12 point socket, remove the 4 bolts on the back of the knuckle holding the wheel bearing in place. If you undid the brake line and left the caliper and bracket on the knuckle, now is the time to remove it.
Attachment 492596
Attachment 492597
Attachment 492598
Attachment 492599
Attachment 492600
Step 9:
Get your wheel bearing and your new front hub, pictured here:
Attachment 492601
Step 10:
I did this at work, so I have access to a press, if you don't have a press, most garages or machine shops will have one, and should press it for a minimal fee.
It will look something like this.
Attachment 492602
Attachment 492603
Attachment 492604
Attachment 492605
Attachment 492606
The finished product should look like this.
Attachment 492607
Here are the finishing steps in order.
Attachment 492608
Attachment 492609
Attachment 492610
Attachment 492611
Attachment 492612
Attachment 492613
Attachment 492614
Attachment 492615
Attachment 492616
Attachment 492617
Attachment 492618
Attachment 492619
Attachment 492620
Attachment 492621
Modified by JDM_DC4_Fanatic at 7:30 PM 7/3/2007
Modified by JDM_DC4_Fanatic at 7:32 PM 7/3/2007
Modified by JDM_DC4_Fanatic at 7:52 PM 7/3/2007
I can't find 98 2.3 cl hubs!....only 97 2.2 cl hubs!...is there a difference between the two that would affect fitment issues???? Need help
Old 05-17-2019, 12:29 PM
  #186
MM Gruppe B
MAD_MIKE's Avatar
'97 Hubs are the same as 90-97 Accord hubs. The CL is an Acura'd Accord Coupe, lots of similar bits and several unique pieces.
'98/99 is when Honda changed the CL from HOR to ROH, so you need to get the 98/99 hubs.
They are hard to find due to the two year wonder of the CL. If Honda/Acura doesn't have them anymore you will probably have to resort to used or nos parts from a yarde.
IMO, unless you track a lot, and I do mean A LOT, there really is no reason to bother with changing over from HOR to ROH.
Quality rotors will last 80K miles, and by then the front bearings are on their way out anyway so replace both.
Don't believe the hype on the ROH conversion, outside of doing lots of track days and burning through rotors, the conversion doesn't really offer much advantage.
If you are wanting larger rotors, Wagon rotors are fine for most. Anything larger, it would just be simpler to convert to 5x 114.3 BP and then you have rotor selection from Honda>Toyota>Ford>etc etc basically any brand that isn't GM. Gonna need new wheels for the larger brakes anyway.
MAD_MIKE is offline
speedjunkie_g35
Appearance Build Threads
474
08-18-2018 03:01 PM
slowpokesi
47
02-12-2018 09:06 AM
JSPECxSEDAN
05-28-2017 09:38 AM
oddmut
Honda Civic (2001 - 2005)
26
12-20-2016 08:31 AM
8atman
08-02-2016 09:04 AM
Quick Reply: DIY - Rotor Over Hub Conversion
  • Ask a Question
Question Title:
Description:
