Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Accord (1990 - 2002) (https://honda-tech.com/forums/honda-accord-1990-2002-2/)
-   -   Differences between 97-99 CL and 98-02 Accord (https://honda-tech.com/forums/honda-accord-1990-2002-2/differences-between-97-99-cl-98-02-accord-2714147/)
Techno Tonis 01-20-2010 08:15 AM
Since Honda doesn't make it easy for me to figure out which parts are the same for which vehicles, I was wondering if anyone knew how similar the CL, and Accord are in construction...Let's compare the 3.0 models of each.
I've searched, and I've searched, and I've searched... but I keep coming up empty handed.
I fail at searching. Please pity me Accord section :(
Mufasa 01-20-2010 08:39 AM
Re: Differences between 97-99 CL and 98-02 Accord
isn't the Cl to the accord the same as what the integra is to the civic?
Techno Tonis 01-20-2010 09:35 AM
Quote:
I was hoping you knew the answer to that. I don't know.
H22_aCCoRd_07 01-20-2010 10:02 AM
97-99cl has the same chassis as the 94-97 accord
Techno Tonis 01-20-2010 10:20 AM
Quote:
Are you sure? Can you verify/explain?
H22_aCCoRd_07 01-20-2010 09:25 PM
yes im sure... pretty much everything bolts up and are interchangable on these vehicles.
turner433 01-20-2010 09:44 PM
The four cylinder versions of the CL and Accord for those years use the same F23A1 engine.
crx_91si 01-21-2010 05:54 AM
Quote:
all aftermarket parts for my 98 CL have been for a 94-97 Accord. Cat-back exhaust, mount inserts, etc... But whats also good about this is that the OEM Acura parts are almost always at least $10-15 more then the Honda parts, so I always cross reference OEM parts between the 2 to save a few bucks
