No power up top after tranny swap!?!
Old 11-21-2005, 04:23 PM
f22pwrdaccord's Avatar
Default No power up top after tranny swap!?!
I recently finished doing a 5spd swap in my 5th gen accord and now when i get on it I have no power up top any clues what this could be...set fuel pressure and timeing back to stock and still have the same problem?
Old 11-21-2005, 04:57 PM
Default Re: No power up top after tranny swap!?! (f22pwrdaccord)
up
Old 11-21-2005, 06:41 PM
P_Adams's Avatar
Sounds like you swapped in a Transmission with a lower final drive ratio. What would this do, You ask?
Whereas your Tach indicated 3000rpm at 65mph before, with a lower final drive ratio it now shows 2400rpm at 65mph; effectively dropping it out of the powerband and making it a real "dog" unless you downshifted.
What car did it come out of?
P
Old 11-21-2005, 06:51 PM
Default Re: No power up top after tranny swap!?! (P_Adams)
swapped in a 5spd off an f22 non-vtec to my f22 vtec motor
Old 11-21-2005, 06:54 PM
also i still have the auto gauge cluster in and the d4 light is blinking what would that indicate something wrong with the motor or it just messed up because the auto is no longer there?
Old 11-21-2005, 07:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you swapped in a Transmission with a lower final drive ratio. What would this do, You ask?
P</TD></TR></TABLE>
well just check the gear ratios for both lx and ex f22 trannys and there the same and the final drives for the auto and manual are only diffrent by the auto having a 4.133 and the manual being a 4.062
Old 11-22-2005, 07:05 PM
welp figured it out on my own apparently hard wiring it into park is a bad idea because it has basicly a rev limiter im think so just used the 5spd ecu like i should have in the first place now its breakin loose all the way up to 4th
conesmasher
07-04-2016 12:39 PM
JToTha2
03-27-2008 04:33 PM
Importn2oRacer
12-06-2007 04:22 PM
accordRE
04-06-2006 09:55 PM
eymnewdc4
02-08-2005 07:48 AM
Quick Reply: No power up top after tranny swap!?!
