98 honda accord won't start, help!
Old 06-28-2015, 04:58 PM
giantsaboveme's Avatar
Default 98 honda accord won't start, help!
I recently replaced the following things on my car:
starter
alternator
battery
My car had been running the past few days perfectly fine after i had someone replace the alternator (finally). This morning i go out to my car to start it and nothing happens. It makes the type of noise that sounds as if it's gasping for air. The radio, lights inside & headlights turn on as well.
Any ideas what it could possibly be?
Old 06-28-2015, 06:11 PM
holmesnmanny's Avatar
Default Re: 98 honda accord won't start, help!
Is the car cranking or not ? Why did you replace those parts ? What was happening ? Did you install parts store parts or real name brand parts ?
Old 06-28-2015, 07:27 PM
It's not cranking, and i replaced them because the starter gave out and then was told i should replace the alternator. it gave out the following day. i bought a new battery just to be safe.
the parts were purchased from autozone and the brand is duralast.
Before i got the parts replaced it was doing what it did now. The radio,lights inside and headlights work but the car won't start.
Old 07-01-2015, 02:47 AM
The next time it doesnt start you need to disconnect the smaller wire from the connector on the starter and test for battery voltage on that wire while trying to start the car.
Old 07-03-2015, 07:19 AM
Lost Again's Avatar
Is this an auto or manual trans?
Old 07-04-2015, 09:21 PM
budduz's Avatar
If it's a manual trans, can you pop start it and get it running?
amyshonda
01-10-2020 12:29 PM
alcr4
01-01-2014 02:32 AM
andrew160
08-08-2008 01:18 PM
Z_Malloc
10-18-2004 07:05 AM
killa_lude
01-05-2004 06:17 PM
Quick Reply: 98 honda accord won't start, help!
