diagnosing 1995 V6 accord tach tripping and P0725 trouble code
Old 01-28-2023, 11:24 PM
n0ah's Avatar
Default diagnosing 1995 V6 accord tach tripping and P0725 trouble code
Car has been sitting for a few months, never had problems with this before. First drive after charging battery and replacing tire, the tachometer is going all over the place. Sometimes the tach reads normally, and sometimes it trips out while the car runs fine. The actual revs are a bit jumpy at times but not enough to slow the car down. If I let off the accelerator and go again it usually fixes it.
Now the car is reporting a P0725 trouble code, and other threads on here suggest it's the ignition coil because of some resistor in the v6 models.
What would be the best approach to diagnosing this issue? I am not a car guy but I am a broke guy so I can figure stuff out and have tools, multimeter, OBD2 reader + live data, etc. Usually I used Chilton Library to figure these things out but my library removed access.
Also, regarding the ignition coil: these other threads keep saying "the" coil rather than "a" coil. I was under the impression that cars have 1 coil per cylinder, is that a different thing in this case? The coil is $50 at AutoZone, do I need one or six? If it's one how would I know which one is causing the problem..
mrbighead
02-21-2016 08:32 PM
91h22cb7lx
07-14-2007 02:08 PM
stevescivic
03-22-2007 07:40 AM
eg4life1202
06-05-2006 04:30 AM
tuffmofo
08-31-2004 11:49 AM
Quick Reply: diagnosing 1995 V6 accord tach tripping and P0725 trouble code
