Check engine light + car sluggish
Old 03-18-2010, 04:06 PM
  #26
Default Re: Check engine light + car sluggish
So my scanner finally came,
I got a P0108 - Manifold Absolute Pressure/Barometric Pressure Circuit High Input
also under ScanTool.net's Sensor Data, I noticed "Fuel System 1 Status: open loop" went to "Fuel System 1 Status: open loop (system fault)".
What do I do now?
kitt is offline
Old 03-18-2010, 04:33 PM
  #27
GhostAccord's Avatar
Test/replace your MAP sensor. PM sent
An "o(sf)" report or open loop (system fault) means that your ECU has been defaulted to run in open loop mode due to a faulty sensor in the fuel system. More than likely being caused by the MAP error code.
GhostAccord is offline
Old 03-20-2010, 03:49 PM
  #28
5v between VCC and ground wires
3.56v between MAP sensor line and ground wires (engine off, car on)
Are those OK values?
kitt is offline
Old 04-23-2010, 08:16 PM
  #29
So I narrowed it down to the MAP sensor or the the ECM (I'm pretty good eh? ). Considering that the voltage was coming ok to the MAP sensor's reference and signal I decided to take the plunge and buy a new MAP sensor. The car has yet to throw a CEL yet, so here's hoping the problem is fixed
Thanks GhostAccord and everyone for their help
kitt is offline
Old 04-23-2010, 09:11 PM
  #30
No problem
Old 05-30-2018, 08:17 AM
  #31
Originally Posted by GhostAccord View Post
Were you are driving a 98 there are no ways to get obd2 codes off your ECU with a self diagnostic procedure that I know of. The do-it-yourself test procedures that I was referring to only work on 90-97 Accords as far as I know. However, there are some auto stores that will scan your OBD2 codes for free.
If you don't have any local shops that will do it for free ask all of your friends, your parents friends if anyone may know someone with an OBD2 code reader for imports. You may be able to find one that you can borrow/have someone come over and read the code(s) for you.
My car is having similar issues 02 honda civic took it to get engine light cheked and the machine read error
Lisy720 is offline
Rupinder Summan
07-10-2014 02:47 PM
CaliRockrr
11-26-2005 04:37 PM
BseriesHatch
09-15-2004 08:46 PM
jeremy.
08-22-2003 06:59 AM
TJP_AccordV6
01-28-2003 06:47 AM
Quick Reply: Check engine light + car sluggish
  • Ask a Question
Question Title:
Description:
