Engine swap not running! I need some help!
i have a 96 accord lx that originally had an f22b2. i just swapped in an obd1 f22b. i swapped the throttle body, oil pump and crank sensor, distributor, and exhaust manifold. i replaced the timing belt, balance shaft belt and water pump while everything was apart.
*im reusing the original wiring harness and ecu.
i got it all together and went to start it and it cranks but will not start. i checked for spark at the coil by pulling the wire off the distributor cap and holding it near a ground. it sparks only once right at the start of when it cranks, then does not continue to spark.
im not sure of where this one wire connector goes. it looks like a ground so this is how i had it grounded:
i ran out of time at the shop so i didnt get to check for a spark with these wires not grounded.
any thoughts on why it would only spark once. and any thoughts on what that connector/ground is, and if it should be grounded to the engine or to the body? im not sure if it should be grounded to the engine or not because i may be creating a ground loop. where should i start?
Re: Engine swap not running! I need some help! (redline870)
ok i figured out why i wasnt getting any spark. i didnt install the right crank sprocket when i swapped the oil pumps so the crank sensor was not reading anything. i had installed the crank sproket that didnt have the little tabs for the crank sensor to read. so that problem is taken care of.
so now i have a new problem. i think its ignition timing. when i try to start the car it cranks and starts for about half a second and then dies. i think it may have something to do with the distributor i swapped over from the original f22b2 engine. the distributor on the original engine has an external coil and the distributor from the new f22b is an internal coil. this is a pic of the distributor from the f22b:
this distributor has 3 slotted bolt holes where the original f22b2 distributor has only 2 slottle bolt holes. is there any way i can swap the metal base on the distributors? any input?
that engine harness ground should attach to the driver side of the intake manifold, on the plenum portion
rat city rex
11-29-2012 12:42 PM
mndb8
18
10-04-2010 02:59 PM
D16Y8-JDMYO
09-29-2006 09:11 PM
