Changed Plugs, Where is all this oil coming from?
I just changed the spark plugs in my 93 EX. I've never worked on a car that you had to go through the valve cover to get to the plugs, so this may be normal, but I'm not sure. When I pulled the wires out the bottom half of each was covered with oil. There was oil standing about an inch or more deep around the top of each plug. I took some pics to show what I found. Is this normal because they go through the valve cover?
This is the car http://memimage.cardomain.net/member...3_105_full.jpg http://memimage.cardomain.net/member...3_106_full.jpg This is the first plug I pulled out http://memimage.cardomain.net/member...83_98_full.jpg http://memimage.cardomain.net/member...83_99_full.jpg This is the first wire as I pulled it out, oil was draining out of it and off it too http://memimage.cardomain.net/member...3_100_full.jpg http://memimage.cardomain.net/member...3_101_full.jpg http://memimage.cardomain.net/member...3_102_full.jpg And down around the top the plug is where the oil was standing http://memimage.cardomain.net/member...3_103_full.jpg http://memimage.cardomain.net/member...3_104_full.jpg What do you guys think? |
you need to change your spark plug tube seals. Since you gotta take the valve cover off, why not buy the whole kit and change all the parts in the kit? It's like $30 from your local dealer.
Re: Changed Plugs, Where is all this oil coming from? (Sardawg)
Thanks Guys!!!
here is a another one with photos: http://www.tegger.com/hondafaq....html https://honda-tech.com/forums/images/smilies/emwink.gif
more than likely it is the rocker orings, they tend to dry up and thin out and let oil pass by them which gets all over the plugs. THIS HAPPENS ALOT ON THE OLDER ACCORDS. I can pretty much guarantee this is your problem. When you replace the rocker orings youll have to buy a valve cover kit as well. It comes with the vcg , tube seals and valve cover grommets. You can get this at any honda dealer. or you can go to http://www.estore.honda.com It will show you the parts catalog pictures like the dealers use and allow you to order parts online from your local dealer https://honda-tech.com/forums/images...s/emsmilep.gif
