cd player and dash clock and blunt lighter dont work
Re: cd player and dash clock and blunt lighter dont work (Metal Honda G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Honda G »</TD></TR><TR><TD CLASS="quote">do i need a fuse or what?
You'll have to tell us. Go look!!!
Your 'blunt lighter' don't work and your asking if its your fuse? First off,how the **** would we know? Just get your *** out there,and check every single fuse on that car. You said in the other thread that you just bought the car,right? So you should check and replace all the blown fuses anyway. Best of luck man,if the fuse(s) doesn't fix the problem,then post back up.
Re: cd player and dash clock and blunt lighter dont work (Ghettokracker71)
Probably a fuse because my radio clock and lighter all went out also when I blew a fuse and it sounds just like what your descriping. Get out the manual that tells you which fuses go where and check the one for that stuff and I bet it is blown but I can't be positive.
its probably a fuse when i got my accord my friends and i where putting my new head unit and subs in and we went through like 2 boxes of fuses
Re: cd player and dash clock and blunt lighter dont work (90accorddx)
yes dude is the fuse they are all in the sa circuit, radio clock and the cigarete lighter or outlet... replace the fuse but also you might want to check why it burned out.. short some wire
