Sandy grinding noise coming from steering wheel ... what does it mean???
Old 12-21-2007, 05:50 PM
NGUSPEED's Avatar
Default Sandy grinding noise coming from steering wheel ... what does it mean???
I just installed an AP1 Steering wheel into my '96 Accord LX. It looks and feels awsome! The only issue is when I turn the steering wheel either direction, there is a sandy, scraping sound coming from it. It did not do it before when I had the original wheel on it. Can anyone tell me what could be causing this and how I would go about solving the problem. Thanks!
Old 12-21-2007, 06:00 PM
RACEPAK's Avatar
Default Re: Sandy grinding noise coming from steering wheel ... what does it mean??? (NGUSPEED)
air in system?
checked the fluid lately?
Old 12-21-2007, 06:14 PM
NGUSPEED's Avatar
Default Re: Sandy grinding noise coming from steering wheel ... what does it mean??? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">air in system?
checked the fluid lately?</TD></TR></TABLE>
Its a grinding sound coming from the steering wheel. It started after I put the steering wheel in today. The original steering wheel didnt do it at all. Im just trying to see if there is a cure for it.
Old 12-22-2007, 06:24 AM
cd555's Avatar
Go ahead and ship it to me and Ill install it in my 96 and we'll see if it still does it. In all seriousness I wonder if maybe the plastics from the steering column cover is touching the steering wheel? Have you checked all clearances in that area?
Old 12-22-2007, 08:31 AM
hondaccord's Avatar
Default Re: Sandy grinding noise coming from steering wheel ... what does it mean??? (cd555)
did you use a adapter, or detachable hub? either way it does sound like its rubbing on some mettle.
Old 12-24-2007, 08:36 AM
NGUSPEED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd555 &raquo;</TD></TR><TR><TD CLASS="quote">Go ahead and ship it to me and Ill install it in my 96 and we'll see if it still does it. In all seriousness I wonder if maybe the plastics from the steering column cover is touching the steering wheel? Have you checked all clearances in that area? </TD></TR></TABLE>
Haha... That could be it. Ill give a closer look since I have time off these next couple days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaccord &raquo;</TD></TR><TR><TD CLASS="quote">did you use a adapter, or detachable hub? either way it does sound like its rubbing on some mettle.</TD></TR></TABLE>
It's an S2000 Steering wheel. No adapter needed.
Old 12-24-2007, 01:41 PM
typeR#0427's Avatar
its probably the cable reel for the airbags. is it coming from the inside, or the outside? if you cant see anything obvious thats probably all it is.
Old 12-26-2007, 08:45 PM
NGUSPEED's Avatar
Default Re: Sandy grinding noise coming from steering wheel ... what does it mean??? (typeR#0427)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeR#0427 &raquo;</TD></TR><TR><TD CLASS="quote">its probably the cable reel for the airbags. is it coming from the inside, or the outside? if you cant see anything obvious thats probably all it is. </TD></TR></TABLE>
It's coming from the inside. How would I go about repairing it?
Old 12-27-2007, 01:28 AM
SuShiBoiiii's Avatar
take off the wheel and look around
Old 12-27-2007, 07:59 AM
typeR#0427's Avatar
i would take it out(airbag), and just make sure that everything is lined up, probably something small
Old 12-27-2007, 08:03 AM
NGUSPEED's Avatar
Thanks for the advice. Ill take a closer look at it soon.
civicdelsol33
12-06-2011 05:09 AM
aberle99
13
01-30-2008 12:37 PM
Damon Reeves
12-26-2007 03:51 PM
RuskeR
10-30-2002 05:59 PM
Quick Reply: Sandy grinding noise coming from steering wheel ... what does it mean???
