Aftermarket Prelude Rear Sway Bar
How close would the fitment be for a Prelude sway bar? The Accord Rear from Progress is only 22mm while the Prelude's is 27mm!
That paired with a better but smaller front = baller? |
Re: Aftermarket Prelude Rear Sway Bar (TheMuffinMan)
I have a Progress rear bar on my Prelude. If you want to measure the overall width of your Accord bar I could compare it to the width of the Progress Prelude bar...if the width is the same I would think it would work https://honda-tech.com/forums/images...es/emsmile.gif
Does your Accord bar look similar? https://i153.photobucket.com/albums/...g?t=1222847229 https://i153.photobucket.com/albums/...g?t=1222847462 https://i153.photobucket.com/albums/...g?t=1222847485 |
See my impression was that they were similar. I'll try to get measurements on my side. I'll see if I can snag measurements. I would imagine everything but the endlinks would be similar.
I appreciate it Hawkze! |
Re: (TheMuffinMan)
I know I wouldn't be surprised if they were very close to the same...and you can always do some custom endlinks pretty easy https://honda-tech.com/forums/images...es/emsmile.gif
^ That was my thought as well, the extra 5mm would be worth it if all it was was additional endlinks
Re: (TheMuffinMan)
Do want 27mm rear sway.http://media.firevortex.net/icons/cu...-green-yes.gif
Re: (hurleyint)
Ugh, you would bring up this topic the day after my 22mm rear sway from progress showed up at my door. https://honda-tech.com/forums/images...s/emthdown.gif
If this works, perhaps i'll just keep it in the box and return it....hmm..... |
^ lol, yeah I gotta take some measurements and see how it goes
The Progress bar is the same for all the Preludes (both of the recent gens) BB4 and BB6 I think? 92-01? And we know the suspension components are similar as are the vehicles weights. |
So I took a look and they seem VERY similar, the stock sway bushings are different, I'm not sure if that silver piece bolted in place of the old or if you had to tap the new holes for it, the stock bushings were closer to where the DC tie bar you have bolts to.
I'll measure it in a sec |
Re: (TheMuffinMan)
sorry this is off topic but what's the blue dc thing connected to the lower control arms and the other blue things... sorry.. I dunno the names of em. I'm curious into upping my handling and I also wanted to bump this cause I'm curious of the outcome. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (scabbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scabbs »</TD></TR><TR><TD CLASS="quote">sorry this is off topic but what's the blue dc thing connected to the lower control arms and the other blue things... sorry.. I dunno the names of em. I'm curious into upping my handling and I also wanted to bump this cause I'm curious of the outcome. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
the thing labeled DC in blue not the blue rods. is sometimes called a SUBFRAME CONNECTER or subbframe bar/brace depending |
Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">
The Progress bar is the same for all the Preludes (both of the recent gens) BB4 and BB6 I think? 92-01?</TD></TR></TABLE> Yeah, technically there is only a 5th gen Prelude Progress bar, but it works fine with either model (4th or 5th) <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">So I took a look and they seem VERY similar, the stock sway bushings are different, I'm not sure if that silver piece bolted in place of the old or if you had to tap the new holes for it, the stock bushings were closer to where the DC tie bar you have bolts to.</TD></TR></TABLE> The silver pieces are the Progress brackets. They bolt in place of the stock Prelude brackets which are weak when up against this bar https://honda-tech.com/forums/images...s/emsmilep.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scabbs »</TD></TR><TR><TD CLASS="quote"> sorry this is off topic but what's the blue dc thing connected to the lower control arms and the other blue things... sorry.. I dunno the names of em. I'm curious into upping my handling and I also wanted to bump this cause I'm curious of the outcome. </TD></TR></TABLE> It's a lower tie bar. It does nothing, just for looks. I don't even have it any more https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
Yeah, technically there is only a 5th gen Prelude Progress bar, but it works fine with either model (4th or 5th) The silver pieces are the Progress brackets. They bolt in place of the stock Prelude brackets which are weak when up against this bar https://honda-tech.com/forums/images...s/emsmilep.gif It's a lower tie bar. It does nothing, just for looks. I don't even have it any more https://honda-tech.com/forums/images/smilies/emwink.gif </TD></TR></TABLE> Gotca, I'll have to check on the mounting points then, we definitely do not have anything similar to the silver bracket on our cars but I did notice at least one tapped thread on either side in the same spot. Didn't get a chance to measure depressingly I couldn't find my jack haha. |
Update.
Stock Accord EX swaybar is 45.5" from endlink to endlink (the bottom of them) |
Re: (TheMuffinMan)
Alrighty, the Prelude Progress bar is approximately 44 - 44.5" across from the endlink tab to the other endlink tab. I measured this with the bar on the car so I could not a get an exact length, but I got very close.
So that's no more than 1" difference which I am very sure you could make for with different endlink mounting configurations. So as far as the length I sure this would work https://honda-tech.com/forums/images/smilies/emthup.gif |
I found a used bar and will probably try to buy it for testing and awesomeness
MOAR UPDATES!
So I got up underneath my car and removed some odd rubber plugs from the general area where the Progress bar's brackets install. This is what I find: https://img357.imageshack.us/img357/...1000536vw4.jpg Now from the closest hole to the back to the other side it's ~ 42 inches I'm not sure because I have to wrap the tape measure under the gas tank and over the exhaust. Further inspection reveals: https://img397.imageshack.us/img397/986/p1000540zm2.jpg Now this is a bracket that holds up the brakelines, but is located in a similar area as the Progress/Prelude mounting point, I'm not sure if the top bolt could come out and be replaced as an endlink piece. That top hole is approximately 6-8 inches away from the closest larger hole which seems feasible for the length of the sway bar (from mounting bracket to endlink) Lastly, here's the stock crappy Accord mounting point: https://img357.imageshack.us/img357/...1000541fc8.jpg Which is a completely different mounting position from where I'd be looking at doing. Does anyone have any input on this? |
Re: (TheMuffinMan)
Wow, it's hard to visualize how everything should work from the pics...I wish I could stick my head in there and look around https://honda-tech.com/forums/images...s/emsmilep.gif
Looks like you might need to drill/tap the holes for the brackets. And that brake line holder, does it have a hardline going into it? Looks like it is mounted on a suspension member, but that couldn't be if it had a hardline. For the endlink, I think you could piece something together with a heim joint on one end and the OEM type of link on the side that bolts to the lower control arm. |
Does anybody know where I can order those Progress rear swaybar brackets?
