Replacing cylinder head bolts
Old 06-26-2011, 12:27 PM
mem94043's Avatar
Default Replacing cylinder head bolts
I recently read somewhere that you should replace the cylinder head bolts when doing a 'head gasket' job. Last week I picked up my F22B2 head (pressure test and valve job) and the shop owner said I would not have to replace the head bolts.
Any opinions out there on this matter?
Thanks,
Mike
Old 06-26-2011, 12:39 PM
poorman212's Avatar
Default Re: Replacing cylinder head bolts
IMO, stock set up...no major damage done, no need to replace the head bolts.
Old 06-26-2011, 01:03 PM
GhostAccord's Avatar
A lot of people seem to think that they are torque to yield. However this is a misconception. I have never seen or read any thing to prove this to be true for the Honda head bolts. IMO they can be reused as long as there are no nicks or burs in them. Soak them in oil over night before you put them back in the engine. Torque them in sequence as prescribed in the manual.
Old 06-26-2011, 01:22 PM
DanielRemains's Avatar
The only reason why you would have to change them is if they have been over torqued.. On some cars it is recommended to change them but on Honda Accord you do not have to and I did not.
moddage
06-25-2010 06:44 PM
biggishjay
04-06-2007 04:08 PM
tom91ita
09-20-2004 06:34 PM
Boost2NA
07-16-2003 01:46 AM
Quick Reply: Replacing cylinder head bolts
