AC Fan & Clutch wont turn off
AC Fan & Clutch wont turn off even when the ignition is off.
I really don't know what else to say to explain this. I have reconnected the wires from where the PO had cut them and all of a sudden the ac fan and loud clunk from the compressor clutch coming on. I as thinking that this was a bad relay but after looking around the internet and seeing that each of these has its own relay I don't know where else to look. Oh also the horn is not working can hear the click of the relay under the radio but now sound. DOH this is a 95 Accord. |
Re: AC Fan & Clutch wont turn off
First thing to look for is that the ac relay is not sticking closed.
Already swapped it out with a new one.
Sounds like that was the issue. Thanks for the update.
By the way we wound up swapping the entire harness that goes under the passenger side fender then it started working correctly.
