96 f22b2 Engine turns over but won't start???any help please!!!
#26
Re: 96 f22b2 Engine turns over but won't start???any help please!!!
took everything apart and the problem lies on the block... warped/dipping .003 between each cylinder
#27
GDD Member
Shoulda done a leakdown test first because 0.003" is still within factory spec for the deck clearance, so there's absolutely nothing wrong with the block. Now that the head is off, snap a picture of both the gasket and the deck and we can see if it was just a blown head gasket or not. Also, I would run your head down to a machine shop so that they can resurface, check valves for leaks, and check the head for cracks.
#28
Yep, try it again with new gasket. Try using the old bolts and make sure you use the proper stages and sequences with torq'in the head back on.
#29
when i took the new head and gasket back off the blow-by was between cylinders1 & 2 and between cylinders 3 & 4 on top of the head gasket and the bottom of the head...it was all black the block was completely clean... what i dont understand is why the problem was worse w/ the new head...the old head had alot of warpage but the problem wasnt as bad so that leads me to belive that someone prviously used a block sealer and i cleaned it off??? i know this car was badly overheated b/c the plastic piece that holds the timing cover on was melted...i just dont want to waste 70 bux on a new gasket and still have this problem...
#30
i am really thinking of trying this again...with my old bolts and new gasket
#31
$70 bux for a headgasket is a bit steep? I've seen them online for $25 or so like this for instance. http://www.autopartswarehouse.com/se...tt=head+gasket
#32
i did do a leak down test...sorry i didnt mention it but all cylinders were leaking into the cooling system...when i took it back apart the evidence was there
acuraTboo
Honda Civic (2006 - 2015)
04-24-2013 04:16 AM
Seroga415
01-18-2008 03:10 AM
