96 Accord LX water leak
on my 96 accord, I found some water leak (water leak) on the pass. side. I think it only leak when the AC is on. What can it be? how do i fix it? thanks.
Re: 96 Accord LX water leak
How much water is there? The AC does produce some water that drips down.
that is normal..make sure they're only water though not oil
I should make it clear. It's dripping from the pass. side dashboard onto the carpet. I'm pretty sure is from the A/C since the water (no smell) drips when the AC is on.
It is a clogged AC drain pipe. I believe it's accessible from the underside of the car - should be a little black rubber tube. Try blowing air through it.
Where is the drain pipe. i was under the car and didn't notice the rubble tube. anyone got a picture? thanks.
