how to remove 3 connectors from ecu?
how to remove 3 connectors from ecu? EVAP cannister?
I just want to be sure that the only thing I need to push down on is on one side and it's the middle clip, push in, then pull the connector out, is this correct? I don't want to break it and it appears to want to be a bitch to get off. Do I need to push in anything on the other side?
Re: how to remove 3 connectors from ecu?
I pushed the tab and pryed from the other side and that seemed to work.
For adding additional pins to the ecu, where do I push the wires through on the firewall?
Do I need to mess with the EVAP cannister. I picked up a prelude EVAP but it appears to have the same vacuum hoses coming out of it and the same vacuum diagrams? I'm thinking the swap guides are saying that the 5th gen accords have only 2 vacuum hoses. My 4th gen has 3 and the same way as the prelude.
http://hondaswap.com/attachments/109...4-scan0002.jpg
http://www.torontoaccords.com/viewtopic.php?f=3&t=50554
