95 Accord Legend 2 Piston Brake Upgrade
#76
Re: 95 Accord Legend 2 Piston Brake Upgrade
ok so i have a 92 wagon, and was thinking about doing the 2 piston caliper, so would i still need to do the rotor size change and bigger caliper bracket? i'm already going to do the cl over the hub rotors jus want to know before i buy all that stuff
#77
He knows where you live!
And you just are not capable of using the same bracket with the upgraded caliper with the different rotors.
#78
If you retain the stock Accord rotor you are only going to use about half the pad - which over time I have a feeling is going to be a bad thing. You will end up eating through half of it and cutting a groove into it.
#80
With the rotor over hub already done on my 95 EX, I understand that I need NSX, Legend, or Prelude calipers. Will the V6 accords from 98-2002 rotors be fine?
#81
Hey i found this hub and bearing assembly and am rather confused.... it doesn't really look like hub over rotor.... but i'm new to the honda accord world and was looking at doing the RoH conversion and legend calipers. Figured this would be a nice place to post this if it did end up being useful.
http://www.1aauto.com/1A/wheel-beari...tm_content=SHF
#82
The 1st gen 3.0CL has 11.1" rotors. These are the rotors you want to use if you're looking for a direct swap. If you want to keep the original HOR design, use '97 3.0CL rotors. If you want to switch to the rotor over hub design of the '98-'99 CL, use the '98-'99 3.0CL rotors. The 3.0CL uses a 25T caliper bracket, so make sure you pick up a set.
I personally didn't find the ROH conversion necessary. I can changed both front rotors in about 45 mins with a slide hammer and air tools.
#83
If you're seriously considering using aftermarket parts, I'd just tasauto's roh kit and be done with it.
#84
i have an accord wagon, swapped the front with a complete odessy spindle n rotor over hub and odessy brake booster and master clyn, stops really good for my turbo h22a plus its 5 lug, just order my cross drilled front rotors for 2001 v tec lude and will put nsx calipers on and report back how much better it will stop then before
#86
However, unless you really want the sex appeal of the two-piston calipers, the Accord V6 caliper uses the same mounting orientation as stock and the same brake pad as the Legend caliper. No funny bleeding procedure, no leading-trailing piston, just the bigger pad and bigger rotor. Plus you can trade in your existing calipers for the cores at the auto parts store without them raising an eyebrow.
But if one wants real sex appeal for cheap, the 1990 Volvo wagon uses 4-piston calipers and has the same rotor thickness...
*Yes, I know I responded to a necro-bump.
#87
Thanks for the input thing is I already have a set of Legend calipers and brackets and I'd like to use them for my turbo build this spring. I was going to do a 5 lug but decided to stick with 4x114.3 for the fact that a buddy of mine is selling me his drag wheels I just home the wdrag wheels clear the calipers.
#88
