95 Accord blowing fuse for the horn
My 95 accord keeps blowing the fuse for the horn. This is disabling not only the horn but also my gear shifter, break lights and cruise control. I replaced my break switch, no luck. Anyone else have this problem and have any advice?
Re: 95 Accord blowing fuse for the horn
i had this same problem on my 94 honda accord ex 2.2l vtec. kept blowing my horn fuse. looked more into the problem and one of the horns was loose breaking the ground and coming back causing to do some sort of short. i tightened it and problem fixed. does yours blow right away?
You need to isolate the short/overloaded circuit. If you don't have an ETM this will be time consiming. Going to be time consuming either way.
Bad grounds don't blow fuses. Bad grounds protect fuses.
jpm0830
02-26-2013 08:33 PM
mrhondafrustration
09-15-2008 11:18 PM
