1992 Honda Accord LX HVAC Blower issue??
Hello,
I have a 1992 Honda Accord LX, lately I've been having this issue with the heater/AC blower suddenly shutting off, not blowing at all and then mysteriously will turn back on again. This has been an intermittent problem now for about 2 weeks. Could this be just a loose connection? What might this run me cost wise just a ballpark figure of course. I know that there is a panel under the glove box where I can screw off and see blower and heater core, but not sure if I should mess with it to see if I can see how bad the connection issue is, if that is what the case really is.
Re: 1992 Honda Accord LX HVAC Blower issue??
When the motor stops working-what happens if you give it a small tap? Could be the blower motor is giving out. When it stops, can you test the voltage at the the connector to see what is going on.
gulfview
10-20-2007 03:21 PM
