replace driver's side headlight bulb - 2002 accord
The driver's side lowbeam on my 2002 accord burned out and I need to replace it.
There's a plastic cover of them that is connected to the frame with plastic push pin looking pins that don't come out unless you can pinch the back of them (which I can't).
The only other things looks like to remove the air filter assembly.
Am I missing something? Is there an easy solution to getting access to and then replacing this bulb?
Thanks in advance.
Thanks in advance.
blackv6
04-30-2006 08:19 PM
sdsviet
08-15-2004 01:54 PM
