6th gen f23a1 to f20b swap thread
#76
Re: 6th gen f23a1 to f20b swap thread
if your still obd2b, your fuel pump isn't coming on because the Pin on the PCB ecu is different. You gotta swap the A15 pin (grn/blk) i believe to A14 position and that **** should start right up.
Using the Auto version of this ECU wont work either. Rev limiter at 5k, no vtec. I tried running a auto PCF ecu and that was my result.
My JDM H23A is running a PCB ecu and these are the steps i had to take.
Let me know how you make out. Oh, and you can get the IAB box from Honda P/N 36361-PT2-014 VACUUM TANK
mike
mike
Last edited by Diego Brito; 05-22-2019 at 04:38 PM. Reason: What wiring harness did you use I’m having trouble with mine
#77
I'm dropping my PS and looping it with a reservoir. :thumbup to Armstrong Steering!
There are a few people with a manual/power steering modified set-up.
Oh yeah! Note: I have heard that in some places finding a used 97-01 Prelude power steering bracket for much cheaper than the dealership isn't the easiest thing to do. It's probably the most popular F/H (F22B/H23 DOHC) swap bracket out there.
I found that the stock P/S pump bracket just needed about a half inch spacer between the head/bracket.
#78
hey it’s been 11 years you still have info on the wire harness?
ho bag
03-18-2008 02:35 AM
stackz
10-02-2006 05:42 AM
