Accord 1998 Rear motor mount...
Re: Accord 1998 Rear motor mount...
It is a vacuum line. If memory serves, on the firewall, on the passenger side, (looking at it with the hood open from the front of the car) it is above and to the left of the motor mount, there is what looks like a dark colored approx. tennis-ball can size "canister". There is a rubber line coming out on the right side of that canister, and then that rubber line connects to a "T" connector. It should connect to that "T".
Vehicle Speed Sensor. The part that reports speed to the speedometer. Also if this is vtec im not sure vtec will engage without it. I have not personally worked on any 98 accords or many automatics so maybe there is a difference. All of the Preludes, Accords and Civics i have worked on have a vehicle speed sensor in that location.
Here is a pic from google.
Here is one from a 99 Accord
This is from an Integra but its a much better view.
Somebody here have a pic of you hydraulic rear mount conection for accord 1998 automatic?
Is the car running and idling ok? If you had a vacuum leak you would most likely idle high.
I was looking and here is what I found. This should give you all the info you need.
Thumping Noise At Cold Start On Honda Accord
Now more important things.... does your speedo work? lol. I checked online and those transmissions should have a VSS.
Having you transmission full of dirt and grime from the VSS port cant be good. I cant imagine your transmission fluid levels are good.
civic565
03-21-2011 05:46 PM
mherrcat
02-16-2011 04:17 PM
