2002 Accord front rotors
Re: 2002 Accord front rotors
Alot easier than a 97 accord! Just remove the caliper (two 17mm bolts). Remove the phillips head screws that hold down the rotor. These are sometimes super tight, an impact screwdriver or even a sharp punch may be needed to loosen these. Now lightly tap on the back of the rotor to break it loose. youre done!
autozone has free online manuals (haynes/ chilton type~ but still useful)
i hate those small retainer screws for the rotors... some people drill them out when they're seized if pb blaster penetrant oil and an impact screwdriver didnt work
PS: when reassembling, i put a dab of grease on the inside hat-to-hub mating surface; i've already experienced rotors seizing to the hub on a toyota & a nissan
PPS: make sure to clean and relube the sliding caliper pins and torque the mounting bolts of the caliper to the correct spec
SlowPokeEg
01-12-2014 10:31 PM
integra7
12-04-2001 12:41 PM
