2001 auto tranny fluid & filter change
Hi , I'm looking for a little insight into changing tranny fluid & filter
on a 2001 Accord LX auto 4 cyl.
I've never done this service on a Honda .
Any insight would be appreciated .
Thanks
Thanks
if u want to do a simple drain and fill. just locate the drain bolt on the side of the transmission, it should have a square hole where u put a 3/8" ratchet in to loosen it.
then you fill it through the dip stick hole i believe, unless on the 2001 accords they have a fill bolt too on top of the transmission.
I am not familar with the 98-02 4cyl autos, but i konw the v6 autos have a fill bolt on top.
and also there is no filter to replace so you dont have to worry about that.
Thanks Eddiebx ,I'm still a little confused .
Yesterday Auto Zone ordered the tranny
replacement filter for me ($31.99) .
Said i could pick it up today .
Some kind of mix up ?
hmmm thats pretty strange, perhaps they ordered you some kind of external inline filter?
i am like 99% positive it doesn't have a transmission filter, well not one thats serviceable anyway.
i think there is one thats all the way in there, which you would only replace during a rebuild. not routine maintance.
but good news, autozone workers arent exactly known for their intelligence so maybe it was a mix up,
if you wanna double check give a honda dealer part counter a call and they can verify for you.
Re: (Eddiebx)
use only oem fluid, honda auto trans are very sensitive about the juice
3 quart is enough for a drain and refill but it will take more if you want to get rid all the juice.(read: 3quart is good enough if you been keeping up the maintaince, a total flush will take 8-9quart)
there's no serviceable filter, the only filter is buried inside the transmission only during overhaul that you need to replace it.
there'a a 3/8 rachet square hole, there's the atf oil drain for all auto honda.
it's on the passenger side.
Re: 2001 auto tranny fluid & filter change (Bugs1066)
accord transmissions for the 5th and 6th gen do NOT HAVE a replacable filter. The Filter is internal to the transmission and cannot be replaced unless the unit is opened.
Also there is no pan on this transmission.
theLemur
12-27-2014 01:01 PM
