1999 accord coupe fuel filter change
so ive located the fuel filter on the passenger side just before the rear wheel, i am going to replace it on sunday and was wondering if anyone on here has done the job and if there is any pointers or problems anyone found when doing it?
Thanks
Thanks
Re: 1999 accord coupe fuel filter change
You probably already did it , but why were you changing it did you see it that was the issue first? I took mine out and found it to be fine just cleaned it up and insured that all the lines were in order. I also cleaned around the pump housing because of the dirt that had built up around the port where you took out all the screws . Hope it went as planed 😊
RCB2
03-23-2010 04:56 PM
