URGENT HELP:Removing dampers from Accord. Already searched
Old 06-28-2008, 02:53 PM
The-Kid's Avatar
Default URGENT HELP:Removing dampers from Accord. Already searched
Hey guys. I'm installing my Eibach springs. I started on the rear as it may give me the most problems. I already remove the upper 2 bolts and the lower bolt connecting to the LCA. Now I'm in the process of removing out of the car. But It's been giving me trouble. The shocks seems really tall and I cannot remove them out of the car.
I even use the spring compressor and compressed the springs in hopes that the whole damper would become shorter. But didn't help. So please help me! Give me tips. I am up for suggestions.
Old 06-28-2008, 06:28 PM
The-Kid's Avatar
Default Re: URGENT HELP:Removing dampers from Accord. Already searched (The-Kid)
Never mind. I found a way. I had to remove my caliper because the e-brake line was in the way. So after I move that aside, I got a whole lot of space. Just for future reference to those.
Old 06-29-2008, 03:15 PM
The-Kid's Avatar
I NEED HELP!!!!
I am currently removing the front shocks. I got the springs and shocks removed but now I cannot use the spring compressor to compress the new Eibach pro kits. As the fingers on the spring compressor is just too thick.... Do I have to bring it in to a shop?
Old 06-29-2008, 03:18 PM
He knows where you live!
TheMuffinMan's Avatar
Do it off your chest!
In reality, for the rears that you did, have a 2nd person stand on the caliper/rotor and push that system down, it'll allow you enough room to maneuver everything out.
As to the front springs, if you can't use the spring compressor you'll have to either try to find a clamp or something then remove it. Or take it to a shop.
What compressors did you get? I got mine from Harbor Freight and they work great (~$8)
Old 06-29-2008, 04:13 PM
The-Kid's Avatar
Default Re: (TheMuffinMan)
Thanks for replying muffinman
Yea I got the rear off perfectly. Everything went rather smoothly for my first time.
Yea the front is a pain so far. Do you know how to do it? As I believe you did this job before? Any help would be awesome.
I've seen the Honda Service manual diagram, and cannot find those types anywhere.
Modified by The-Kid at 5:52 PM 6/29/2008
Old 06-29-2008, 05:01 PM
Hey Kid,
Yeah I did it on my car a long time ago. The stock setup you'll want to have spring compressors or mount it and loosen it slowly and prepare for a POP when the nut is off the threads.
My vote would be to go the safe route as loosening it yourself w/out a spring compressor can be dangerous
Old 06-29-2008, 07:55 PM
The-Kid's Avatar
Well I did the dangerous route. Took it off. I knew it was going to pop, so I kinda tied the springs together with some wire. It helped a little.
The good news it the new eibach springs are shorter than the stock, but it seems I still need to compress it more. And springs compressors wont fit in between the springs. I don't know what else to do...
Worst come to worst, I'll go to Pepboys or something.... How much would a shop charge for just installing the top mount onto the shocks?
Old 07-01-2008, 09:07 PM
dragonfly2k3's Avatar
Default Re: (The-Kid)
you cant get any threads on? if you can get the nut started you can just thread it down and it will compress the springs.
91GEDHATCH
Suspension & Brakes
02-19-2011 08:39 PM
JDMEF
07-22-2010 09:37 AM
M2nR
13
06-24-2006 07:48 PM
ntegraGS-R
01-10-2006 03:48 PM
Quick Reply: URGENT HELP:Removing dampers from Accord. Already searched
