92 Accord EX Tranny Problems
Old 06-06-2009, 06:41 AM
craiger28's Avatar
Default 92 Accord EX Tranny Problems
I do not have an "S" light just a D4 light blinking. It blinks a code 7 and 8. I have replaced the VSS, both shift solenoids, and the TCU. What is the problem? It shifts fine if you shift it manually but when you have in D4 its just in third gear. BTW, does anyone know where to get the transmission codes for this car??
HELP !!!
Old 06-06-2009, 09:47 AM
birdman86's Avatar
Default Re: 92 Accord EX Tranny Problems
Is there anyway you can go to an advanced autoparts or another parts store to get the codes read?
Old 06-06-2009, 01:27 PM
craiger28's Avatar
No. Where can I get the codes???
Old 06-06-2009, 01:43 PM
accord99power's Avatar
google it or use the search in the top right hand side of this page.
Old 06-08-2009, 12:49 PM
craiger28's Avatar
Been there done that, nothing.
Old 06-08-2009, 08:34 PM
KWayRacing's Avatar
You have a bad TCM, or bad wiring to the solenoids(SHift and Torque Converter.) Where did you get your replacement TCM?
Old 06-09-2009, 07:34 AM
Frank Allen's Avatar
You need to get the codes first, also the tcu has to be the right one , different on ex than lx, one over looked thing ive seen in my 92 is the main fuel relay pig tail, some had bad solder joints, also the relay itself, this sends a voltage to the tcu , if its not there then the tcu fails.
Frank allen
Old 06-12-2009, 04:05 PM
KWayRacing's Avatar
bump the above Have seen main relay be the reason and also TCMs are different from year model/ trim level. I always try to match the P/N on the TCM.
92_cb7
08-17-2018 02:55 PM
d9h
04-24-2011 11:12 AM
beeasy12
03-21-2011 01:28 PM
justin3po
09-20-2008 02:54 PM
atc1
11-16-2007 11:55 PM
Quick Reply: 92 Accord EX Tranny Problems
