1995 Accord 4-cyl 4-door Antenna Mast Install
Is there anyone out there who knows the correct sequence when installing the antenna mast on my Honda? I understand that if you feed it into the motor at the right time after turning on the radio, it should completely lower the antenna. This is my first time doing this by myself, so any help with any part of this process is welcome.
Thanks,
Ben
[Modified by bdemore, 6:42 PM 5/17/2002]
Thanks,
Ben
Re: 1995 Accord 4-cyl 4-door Antenna Mast Install
This link has very good instructions for replacing the Mast only.
http://antennamastsrus.com/Honda/Acc...t%20Accord.htm
Good luck
Colin
Good luck
Colin
Good luck
Colin
Good luck
Colin
