1993 Honda Accord LX Station Wagon
First day I got it in noverber of 13
First day I got it November of 13
Cracked left tail light I got fixed.. There was a drywall screw holding the left trunk lens on in this pic lol
First time i cleaned the air manifold body
Don't ask why the strainer is there because I sure as hell don't know
After a nice bath
The interior is pretty decent for the age of the car
The headlights of my dreams
Tear down of the engine. Exhaust manifold and down pipe removed and the A/C/ lines gone
The disfigured head gasket.. Ain't it pretty!!!!!!
The head after I dropped it. In the process of moving it i dropped it and it broke the sprocket.. you'll see it broken in the picture three below this one
Alot more taken off and wiring harness labeled
Cylinder One AFTER some cleaning done.. This is where the head gasket was leaking AF fluid... It looked alot worse then cylinder 2 did
Broken Sprocket
Finally Dropped the engine and tranny
New reman head.. Swapped out the sensors and we got a go
Block stripped of all moving parts
Some of the moving parts and covers lol
The biggest moving part
Time to clean clean clean
After some cleaning and on to sand blasting
Sand Blasting after math.. Ain't it pretty
Just getting started on this side
looks alot better then when I started cleaning
the other side
Back of the left control arm spindle
Front of the left control arm spindle
Back after scrubbing,sandblasting and wire brushing it looks almost new
front side of cleanliness
Prepped fro some paint
THE PAINT!!!!!!! YES its PURPLE!!!!!
I must have been drunk taking this picture cause I sure as hell don't remember why i took it lol
New Detroit Axle Lower and upper control arms, Inner and Outer Tie Rods, Cleaned and painted sway bar, New brake lines, and struts. Rights Side
Left Side
Spindle with paint job and new balljoint pressed in plus the disk brake cover installed
Ok guys and gals I've had this car for over three years now and the head gasket blew. So I decided to do some rebuilding and upgrading while I'm at it. Any ideas. I would like to upgrade my speedo cluster and front bumper. I'm already getting the harmonic balance or Shaft removal kit for a little more hp but what else can I tweek to make it more fun.
After a nice bath
Broken Sprocket
the other side
Left Side
nmaz23
21
11-11-2008 08:53 AM
Jay J
68
01-15-2008 07:42 PM
