1993 ABS trouble codes
Quick question, trying to find it in the DIY section but couldn't locate it. My abs light came on and trying to pull codes for it, I know how but I'm trying to find info on what each the codes mean. Pretty sure its the sensor near the wheel because it comes on and goes off intermittently. anyone know a website or know the sensor codes ones off hand?
Re: 1993 ABS trouble codes (srlance24)
http://www.bba-reman.com/hondaalb2computer.htm
Code / Fault 1 Hydraulic pump motor over-run (contact BBA) 1-2 Hydraulic pump motor (contact BBA) 1-3 High pressure leak (possibly modulator) 1-4 Pressure switch (contact BBA) 1-8 Pressure accumulator 2-1 Handbrake warning lamp switch circuit faulty 3-1 Right hand front rotor damage 3-2 Left hand front rotor damage 3-4 Right hand rear rotor damage 3-8 Left hand rear rotor damage 3-12 Different tyre sizes fitted 4-1 Right hand front wheel sensor 4-2 Left hand front wheel sensor 4-4 Right hand rear wheel sensor 4-8 Left hand rear wheel sensor 5-4 Right hand rear wheel lock 5-8 Left hand rear wheel lock 6-1 Front fail safe relay 6-4 Rear fail safe relay 7-1 Right hand front modulator solenoid valve 7-2 Left hand front modulator solenoid valve 8-1 ABS operation fault 8-2 Electronic control unit (ECU) fault 8-4 Electronic control unit (ECU) - internal circuit fault -------------------------------------------------------------------------------- |
Re: 1993 ABS trouble codes (kjmoy)
Thanks for the helpful info! https://honda-tech.com/forums/images/smilies/emthup.gif
