Swap questions
Swap questions
Specs are as follows... 1990 accord coupé F22A6 auto transmission. Blown motor....
1993 accord 4dr F22A1
standard transmission. Wrecked
1993 F22A1 everything including transmission, harness, fuse box, shifter, pedals, dizzy. To be mounted into the 1990 coupé
swapped everything over. Successful tranny mount welded, brake and clutch pedals with clutch and slave mounted. Swapped standard shift lever. Dizzy swapped. ECM swapped. Only wiring left to finish.
Plugged in all but three plugs to the engin harness. One is to small and different wire colours. Another is different in shape with one wire missing. These are on the passenger side of the motors bay. And one I believe is for the air con which I won't need as I did not keep it. (Drivers side) The other two are my concen.... I have been on one other forum asking these same question, with no avail. Any ideas?
Cheers
Cheers
Re: Swap questions
Do you mean the plugs
These two do not match and figured out that the one with the red wire is (maybe?) for the cruise control which I was going to use. But not nessesary
Top set fits together, middle set does not match and one wire more from the 90. Bottom set the plug from the 90 just a bit to big to fit in
Re: Swap questions
Viktor Kolos
Honda Accord (2013 - 2015)
04-05-2019 01:14 PM
