1992 accord lx, Idle Air Control Valve Were Is It???
#51
Re 02 accord runs bad after warm like in limp
after engine replace car runs good for a few miles then it runs bad like its in limp mode, goes in lower gear Honda dealers in ind wont work on after engine swap, showing no codes replaces ecu , I am at my end:
#53
Re: 1992 accord lx, Idle Air Control Valve Were Is It???
for you guys with the rpm surge while in idle, change the the plastic PCV on the valve cover. the spring inside may break over time.
