1991 Accord speed indicator
First S green light came on blinking
Second orange "check engine " light illuminated Third , the speed indicator needle began to oscillate Fourth, the speed indicator shows zero Car appears to run fine. Any ideas, recommendations? |
Re: 1991 Accord speed indicator (janelectric)
sounds like u could have a bad v.s.sensor...
Make sure the problem is the speed sensor. Check the ECU code and it should be 17. To check the code, check http://www.c-speedracing.com/faq/06.php
If so, I'm having the same problem in the same car. I bought a new speed sensor on eBay for $23.95 but I haven't installed in yet. In fact, I'm having trouble finding where it goes. It's embarassing because I just put this tranny in about a year ago and I thought I remembered how the speed sensor apparatus was set up. Any tips on installing new speed sensors? |
Ussually if the intake isnt in the way it is easier to reach. but it depends on if you got the whole unit with the gear or just the sensor. either one its a few 10 mm bolts that hole it on.
I have on for sale of an f22 tranny if needed. |
Re: 1991 Accord speed indicator (kulrevon)
I finally got around to replacing my speed sensor. It's not too bad if you know what to do (which I didn't) https://honda-tech.com/forums/images/smilies/emwink.gif
Here's how I replaced the Vehicle Speed Sensor (VSS) in my 1991 Honda Accord LX: 0. Disconnect battery. 1. Remove the air intake. 2. Remove the two 12mm bolts that hold the rearmost transmission cable bracket. You don't have to disconnect the cable (although it wouldn't hurt) but disconnect the bracket so you can move it slightly out of the way and it gives you much easier access to one of the VSS bolts. This is the step that will save you much time and energy. 3. Remove the two 10mm bolts that hold the VSS in. One of the bolts is also holding a bracket that the 3-pin cable hooks onto. 4. Disconnect the 3-pin cable from the bracket and the cable that it plugs into. 5. Remove the VSS and the little pin that sticks out the bottom (I don't know what it's called.) 6. Put the new little pin into the hole on the tranny and install the VSS over it. 7. Rebolt the VSS, transmission cables, and air intake. Reconnect battery. I hope this helps someone. - The Heep Modified by the heep at 9:36 PM 8/29/2005 |
Re: 1991 Accord speed indicator (the heep)
Follow-up:
Replacing my speed sensor was the greatest thing I've done since I've owned this car. Not only does the speedometer work, but my idle speed seems to have raised by about 200rpm (thus solving my low idle problem) and for some reason, my cruise control works again. I'm really surprised about the cruise control because it hasn't worked since I've owned the car and the speed sensor has only been out for a few months. |
hey guys im having the same problem wit my vss but i cant seem to find it can anyone help me thanks
Originally Posted by Ghostyman
(Post 17288531)
BR gr00ve |
Originally Posted by carlos1991
(Post 41130081)
I have 2.0 carb. and the vss is -- when you stand next to the passenger, front tire -- look down the left side of the tranny. right under air intake pipe. I think it was the only thing there with wires connected. may be with 2 small pipes leading to it. check this one out. http://techauto.awardspace.com/vss.html BR gr00ve |
Originally Posted by gr00ve
(Post 47601964)
Damn. This one sounds so easy. :D Cannot manage to get the socket over the bolt, as the bracket is very close to the bolt head. any tips?
BR gr00ve I have the same problem here. I got it all out of the way but there isnt enough clearance around the bolt to get a 3/8" drive 10mm socket on it. I've applied pressure to the bracket to try and bend it as flat as possible still no luck. I am going to try a 1/4" 10mm and see if that is a bit slimmer. |
My 3/8" drive fit over the 10mm bolts okay. Ghostyman's tip to unbolt the transmission cable bracket was a big help.
The hardest part for me was getting the 3-pin cable unplugged without breaking the female side. A small nail ended up doing the trick. |
1 Attachment(s)
people people ******remove the bracket****** that attaches to the support on the back of the engine. its one bolt and a nut to remove this bracket this will solve all your problems
Originally Posted by 90LXaccord
(Post 47616117)
Any luck gr00ve getting your apart?
I have the same problem here. I got it all out of the way but there isnt enough clearance around the bolt to get a 3/8" drive 10mm socket on it. I've applied pressure to the bracket to try and bend it as flat as possible still no luck. I am going to try a 1/4" 10mm and see if that is a bit slimmer. tried everything I could possibly think of. Will take 10mm socket and slim it down a bit, and then see, what happens. Should work like this. I just want to take it out to see, if everything is ok. Mine has intermittent speedo problem. One time works, another not. Couldnīt be bad connection, checked it. I think it could be because the car has been standing in garage for a while. What comes in the two small pipes? oil, or cooling? BR from Iceland |
Originally Posted by jdmcertified909
(Post 47719425)
Mine has the connector on the bracket, seperate from the vss body, so there is a bracket coming along the body of the vss. bolted to the inner bolt. There is the problem. Bracket is too close to the bolt head. BR |
what year? what model? how many cylinders?
are you guys using 1/4 inch drive socket????? if so your doing it wrong you need 3/8 socket with extension and 3/8 wrench
(Post 47727914)
engine: F20A2, 2.0L carb, 4cyl SOHC
(Post 47727914)
the picture above is not the same as I have. |
oh you have the f20a2 weird my 91 has a f22a4 in it *edit* mine is an lx maybe thats y but my 90 accord has a f22a6 in the ex
(Post 47753850)
I live in Iceland! lots of different shi* cars can be found only here in the world. :D |
