1990 Accord Fuel Smell and During Chock It Idles Up & Down
I have a 1990 Accord and am having problems with it having a fuel smell every once in a while and during the chock it idles up and down. I have checked the fuel lines, fuel filter, injectors and vacuum lines, but nothing appears to be bad. The car has 243K miles on it. From what I can tell it may be a problem with the emissions evaporator, but I do not know. How do I check the system? Would something else be causing this?
Re: 1990 Accord Fuel Smell and During Chock It Idles Up & Down (ss8151)
Doesn't anyone know anything about this? The fuel smell is happening more often now.
try bleeding your cooling system
and tell us how it goes |
lol the thermowax valve on the manifold is out of adjustment. take the 2 phillips screws out, and tighten the white plastic thing in there with a large screw driver. not real tight, just screw it back in.
fuel smell is most likely evap system failure. get a repair manual from the auto parts store and it will walk you though diagnosing it. |
