1/4 Mile Times and Set-Up Used
#226
Re: 1/4 Mile Times and Set-Up Used
92 accord coupe
stock cams
motor specs
h22a1 block
f22 crank rods
jdm h22 pistons
kings main rod thrust washer kit
nippon std piston rings
stock head with mild port by me
also performed and did lap job on valves saved alot of money and felt good doing it myself
h22 stock intake manifold reworked with oem iab plate
70mm tb
ebay header with 3inch collector
3inch exhaust with morso spiral flow muffler to a 3inch flow sound muffler
450cc injectors
9lb flywheel
4 puck unsprung cluth
h23 casing with h22a1 gear set
the car was street tune in fl but the motor crank spun a bearing due to having a stock crank that was already warped to get fixed lasted almost a year. So i rebuilt bottem end again with same components but with a standard crank.
So basically the motor is running on a street tune done in florida by me just waiting on tuning supplies to come in and then i will retune. But these are the results i have so far.
u might have to really look to see some of the times on the slips. so bare with me.
keep in mind these are in a accord
these are the two best times notice the difference in the mph change
my intake system on the 9.17 pass is a 3inch cold air going into the fenderwell behind the lower front bumper.
break down of the 9.17 pass
60ft----2.25
330----6.0488
1/8th --9.1706
mph----78.95
and the 9.08 pass was with same intake but with a 3inch velocity stack. looking to go 8.80 at best with a tune when i get my tuning supplies.
i'll give the break down as it's kinda blurry.
60ft ---2.19
3.30----5.970
1/8th---9.085
mph----79.498
the vstack shocked the hell out of me
and this was on a different track it was pretty slick i really couldn't drive the car like i wanted b/c the car on my 1st and 2nd past spun 1st and 2nd gear really really bad so on my 3rd past preloading launching at 3000rpm feathering the throttle when i felt the car start to spin i shifted to 2nd gear at 6500rpm the tack went to 5000rpm then climbed to 7700rpm i grab 3rd gear and pick up my time slip and surprise it felt like a 9.50 pass. That fooled the hell out of me so i'm never going to that track again b/c of the shitty track prep past the starting line the other track is a whole lot better.
so what's the fastest anybody has been on true street tires not drag radial in a prelude accord chassis. as i'm lookiing to get in the 8's with mild port head and stock cams.
stock cams
motor specs
h22a1 block
f22 crank rods
jdm h22 pistons
70mm tb
450cc injectors
9lb flywheel
60ft----2.25
330----6.0488
1/8th --9.1706
mph----78.95
60ft ---2.19
3.30----5.970
1/8th---9.085
mph----79.498
#227
1/4 time:16.0553 @ 88.70mph, (Ran 15.9 with no slip the machine quit printing)
Reaction .5451
60ft 2.5435
330ft 6.9899
1/8 mile 10.5176 @ 70mph
HP:200 at crank (guess)
torque:
Car: Accord 4 door
Year: 97
Stick/Auto: H22A LSD Auto MPA1 or MPA6
Series (lx,ex,sh): SE
Engine: JDM H22A
Misc: Bad O2 senor
Mod Setup: 2.25 Exhaust (run with muffler removed) 2in Cat, Accord Throttle Body and Stock intake, Made a little difference with no filter
This car lanches hard put doesn't pull very fast after 1st gear need a cold air intake, its sucking hot air from engine bay. Any Performance suggestions?
Reaction .5451
60ft 2.5435
330ft 6.9899
torque:
Car: Accord 4 door
Year: 97
Engine: JDM H22A
Misc: Bad O2 senor
#228
1/4 mile: 15.960 @86.39mph
HP: 130whp
torque: 142wtq
Car: Accord Sedan
Year: 1997
Stick/Auto: 5-speed
Series (lx,ex,sh): LX
Engine: F22B2(I/H/E)
Weight: 3040 lbs(with me)
Waiting for good weather to run again with 331 whp and 338 tq
HP: 130whp
torque: 142wtq
Car: Accord Sedan
Year: 1997
Stick/Auto: 5-speed
#229
UPDATE:
14.7380@101.76 mph
HP: 331whp
torque: 338wtq
Car: Accord Sedan
Year: 1995
Stick/Auto: 5-speed
Series (lx,ex,sh): EX
Engine: F22B2(forged Bisimoto rods/pistons) H22A head with GT3076R turbo on 10 lbs
Weight: 3330 lbs(with me)
Spark breakup at high rpm in 2nd and 3rd plus shitty tires/rims lead to bad traction/times.
Fastest run, although mad me look painfully slow when going up against s/c mustang V8 with NOS.
14.7380@101.76 mph
HP: 331whp
torque: 338wtq
Car: Accord Sedan
Year: 1995
Stick/Auto: 5-speed
civiccoupe94
03-28-2011 09:37 PM
fernancivic
19
07-01-2009 02:34 PM
