02 Accord F23A4
I went to TAS AUTO (GREAT store BTW) and purchased several things. Among them was the VTec Valve Cover Gasket Set.
I'm having trouble with the spark plug tube seals. I tried popping them off with a needle nose, but 2 of them ripped and the spring came out of the seal. I haven't removed the other seals for fear of the same happening with them. I also tried to pry them off with a small screwdriver but that didn't work either. I don't wanna chip off some metal shavings by prying too hard. Am I just trippin? or is there a trick to getting them off? Can anybody explain how to do this seemingly simple task? I appreciate anyone's feedback. |
Re: 02 Accord F23A4
time for you to buy a new vavel cover gasket set with upper and lower tube seals.... they usually tear on high milage engine when u try to remove them.
Re: 02 Accord F23A4
yes, i belive so, they are pretty worn out..
