"Brake Lamp" light went on???? is that meaning a problem????
Old 07-14-2014, 01:14 PM
  #51
hondalion's Avatar
Default Re: "Brake Lamp" light went on???? is that meaning a problem????
What little black plug? I cracked my center tail light on the trunk and the warning lamp came on. Went ahead and replaced the assembly and the lamp is still on. The light works fine it's just the warning light won't go off it seems.
EDIT: 99 accord coupe v6
Old 04-27-2016, 02:57 AM
  #52
Gina Griffin's Avatar
My brake lamp light is on also....brake lights all work properly...brake switch under the brake pedal has been replaced. I'm also having problems taking the car out of park. Any suggestions? This car is driving me crazy!
Old 06-01-2016, 03:14 PM
  #53
Michellecar's Avatar
It doesn't have anything to do with the tail lights or the emergency brake, boys. It has to do with either:
A. The master brake cylinder--which may need to be replaced if the brakes sink when you depress the pedal to stop
B. There may be debris or pockets of air bubbles that can develope when you twist the brake fluid cap off--you may need to flush the fluid and refill it.
Always remember to wipe the brake fluid resevoir before opening it because the hose is prone to being clogged by contaminates/particulates and never shake the brake fluid.
Old 06-02-2016, 11:35 AM
  #54
fcm
Old Fart
fcm's Avatar
Wrong^^^ the brake warning light comes on when E brake is applied or you are low on brake fluid or brake fluid level switch is defective/stuck. 94
Old 06-02-2016, 12:11 PM
  #55
Actually it's not the e-brake. The e-brake is a different light.
Old 11-01-2022, 07:06 PM
  #56
Lritchie0122's Avatar
Default Re: "Brake Lamp" light went on???? is that meaning a problem???? (bushrat)
Originally Posted by mystre23
lakeman i forwarded a copy of the brakeswitch pic to your profile email, i couldn't figure out how to attach it to this replay. let me know if this helps
Can you send a picture of the brake lamp under the steering column plz
804tuned
Lighting
01-17-2010 05:44 AM
alpha_1
02-19-2009 09:02 AM
EASY101
07-10-2006 02:26 PM
D-Day
05-23-2001 06:31 PM
Quick Reply: "Brake Lamp" light went on???? is that meaning a problem????
