What do you do when you stop?
Old 07-17-2001, 06:59 PM
Chairman Kaga's Avatar
Default What do you do when you stop?
I've always wondered this, from my first days as a driver behind the wheel of a 71 Super Beetle (I've come a long ways, huh?).
When you come to a stop, say a light, is it better to leave the car in gear and just hold in the clutch, or shift into neutral? And how far from a complete stop before you put it into neutral? Typically, I gear down if I have time, and slip it into neutral at about 15-10 mph, right before the engine starts to act like it wants to stall. But I'll usually only do this at a light or extended stop. For just a sign, I'll gear down, clutch in right before the complete stop while sliding back into first, then off again.
Technically speaking, what's the best way to stop???
Chairman Kaga is offline
Old 07-17-2001, 07:28 PM
BoM
BoM's Avatar
Default Re: What do you do when you stop? (plugg)
if im in 2nd 3rd or 4th i keep it in gear and brake...til it gets to 1000rpms....before it stalls then put it in neutral and brake the rest of the way...5th gear i downshift to either 3rd or 4th depending on how fast im going then do that.....
BoM is offline
Old 07-18-2001, 08:34 AM
ALF
ALF's Avatar
Default Re: What do you do when you stop? (chairmankaga)
I simply apply the brakes...and as my speed decreases to about 20 MPH, I throw it in neutral.
ALF is offline
keithv's Avatar
You should leave the car in neutral during a stop. If you have the clutch in, you can wear out your thrust bearing.
Also, I usually just go from whatever gear I am in to neutral when stopping. Brakes pads are a hell of a lot cheaper to replace that trannies.
keithv is offline
Old 07-18-2001, 10:01 AM
nerdish's Avatar
Default Re: What do you do when you stop? (breaka_1_9)
I push the clutch in, go 5-4-3-2 with my clutch to the floor.. when I stop I shift to 1, and keep my foot on the floor. But apparently leaving the clutch in is bad for stuff... I dunno.
And then when I'm stopped, I usually turn down my music a little because I don't want to be 'that guy.'
nerdish is offline
Old 07-18-2001, 10:15 AM
keithv's Avatar
Default Re: What do you do when you stop? (nerdish)
Nerdish 2 things....
1. Leaving the clutch in is indeed bad for your motor. The thrust bearings keep the crank from moving side to side. When you push the clutch in these bearings are absorbing the force of the crank being pulled to the side. These bearings would be expensive to replace as they are part of the bottom end...
2. I am not attacking you, but why shift through all the gears? Is it really necessary? Use your brakes more and you car will like you better for it.
keithv is offline
Old 07-18-2001, 11:47 AM
Dat's what I heard too. If you look at the design of a clutch you'll see why it causes undue wear and tear to keep the clutch on the floor. Not that it really matters, or anything .
When I pull up to a stopsign or light I usually play with the stereo. I roll in neutral as much as possible.
raene is offline
Old 07-18-2001, 11:49 AM
eurodeseo's Avatar
Default Re: What do you do when you stop? (raeneshadow)
We discussed the rolling in neutral thing in the IT-R forum a few days ago. Here's a link to the thread.
https://honda-tech.com/zerothread?id=51853
eurodeseo is offline
Old 07-18-2001, 12:18 PM
BlackAckeR's Avatar
Default Re: What do you do when you stop? (eurodeseo)
No advice on coming TO a stop, but once there, I now keep my foot firmly pressed on the brake... Until yesterday, I would not do that if I was on a flat surface. I was sitting fifth car back from the red light when an SUV in the third position must have slipped his foot onto his gas, floored it into the pickup in second position which then plowed into the car in front pushing it out into the intersection (where it almost got hit again)!
Wow, what an eye opener that was!...
BlackAckeR is offline
Old 07-18-2001, 12:19 PM
Trinity's Avatar
throw my car in neutral.
[Modified by Trinity, 9:21 PM 7/18/2001]
Trinity is offline
Old 07-18-2001, 12:45 PM
SOHCArchangel's Avatar
Default Re: What do you do when you stop? (Trinity)
neutral
SOHCArchangel is offline
91b18a1ls
07-10-2011 10:54 PM
tazeat
General Discussion and Debate
211
10-14-2009 04:24 PM
JDMH22HATCH
Transmission & Drivetrain
12-01-2008 05:15 PM
XplicitzOldSkoolDA
04-14-2008 03:57 PM
95turbodteg
Honda Civic (2006 - 2015)
37
09-15-2007 08:18 AM
Quick Reply: What do you do when you stop?
