Water Cooling
Old 02-04-2005, 05:41 AM
Default Water Cooling
to all the owners of custom PCs here. does water cooling help alot for overclocking? whenever i play source, my pc gets louder as the cpu gets hotter. my idle is around 33C though so i guess its not that bad.
is it worth going water cooling?
im running p4 2.4 800fsb @ 3.2 1000+fsb
i wana get to 3.6 @ 1200fsb
Rice Is Best is offline
Old 02-04-2005, 09:56 AM
put title here
b_ack51's Avatar
My roommate has it, pretty nice. I'm just too worried of water spilling. I'd say if you were a hardcore gamer, then do it.
b_ack51 is offline
Old 02-04-2005, 10:01 AM
loki2323's Avatar
Default Re: (b_ack51)
I have my 3.2ghz running @ around 3.65ghz
idle temp is about 31-32 and usually when gaming I get up to around 45
What kind of heatsink and fan are you using? Before doing any water cooling you might want to try an aftermarket one.
loki2323 is offline
Head Of Bespoke
Rguy's Avatar
It's more for bling, nice fans and a heatsink are fine.
Rguy is online now
Old 02-04-2005, 10:19 AM
Default Re: (loki2323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loki2323 &raquo;</TD></TR><TR><TD CLASS="quote">I have my 3.2ghz running @ around 3.65ghz
What kind of heatsink and fan are you using? Before doing any water cooling you might want to try an aftermarket one.</TD></TR></TABLE>
i have a thermaltake case with 7 fans (2 front, 2 side, 2 read, 1 top) and thermaltake copper fan with auto speed selection depending on heat.
Old 02-04-2005, 10:35 AM
The Notorious Frosty's Avatar
Default Re: (Rice Is Best)
I did a DIY watercooling setup and I still couldn't break 3ghz stable.
(P4 2.4 800fsb)
You can do a DIY kit for &lt; $100 though. Get a heater core from Autozone. Order the heatsink. Go to homedepot for the plastic tubing. Order an inline water pump (you won't find one in stores, I tried) Then just buy a switch at autozone. I carefully cut and filed one of the bay covers in the front of my case and put a switch to turn the pump on and off.
The Notorious Frosty is offline
ITLNstallion818
General Discussion and Debate
15
02-29-2008 03:21 PM
AWDstylez
01-02-2008 07:36 PM
GI8U2racing
09-08-2007 07:51 AM
Drew M
27
04-30-2004 06:51 PM
james8t2
34
04-27-2004 08:46 AM
Quick Reply: Water Cooling
