Go Back  Honda-Tech - Honda Forum Discussion > Community Forums > General Discussion and Debate
Reload this Page >
There are E85 stations popping up in my area.. why is that lately?
Old 07-08-2019, 05:41 PM
1990IntegraLS's Avatar
Default There are E85 stations popping up in my area.. why is that lately?
I hadn't put in any gas in my cars for more than two months. Went today, and E85 was everywhere, and some pumps were covered up with red bags. I did find a station with E10 and nothing else.....but how long will I be able to use E10? Not even my Congressman or State Rep knew.
I know there has been a loosening of regs regarding E15, the epa can move on that. I don't know much about the regs for E85, other than all of a sudden it's everywhere.
Anybody have thoughts on this?
Otherwise, I have been seeing a newer swap engine here in these forum, but haven't paid any attention.
What is the most modern engine I could put in my '90 LS (DA)? That swap parts are already being made?
K20a2
H22A?
Thanks
1990IntegraLS is offline
Old 07-08-2019, 05:47 PM
Moderator
TheShodan's Avatar
Default re: There are E85 stations popping up in my area.. why is that lately?
Thanks
This is a general debate discussion on the particulars and nuances of E85
TheShodan is offline
Old 07-08-2019, 05:59 PM
Bloody Beaver
.Beaver's Avatar
Default Re: There are E85 stations popping up in my area.. why is that lately?
What rock do you live under? We’ve had E85 stations here for at least a decade.
.Beaver is online now
Old 07-08-2019, 06:06 PM
I've see a few, but rural Texas has not been going alone with the stupid waste called ethanol....willingly. That's why I like it here. Ethanol ruins tractor motors (farm and ranch), boat motors, small engines, etc.
Old 07-08-2019, 07:22 PM
tony_2018's Avatar
I have a feeling this is more about what to swap in your da than talks of e85 stations showing up.
tony_2018 is offline
Old 07-08-2019, 07:28 PM
DaIll1's Avatar
The E85 doesn't ruin them, not designing and tuning for the much higher volume needed is what ruins them.
DaIll1 is offline
Old 07-08-2019, 10:47 PM
Tickle-shits
Tokyosmash!'s Avatar
I know my SVT isn’t going to play well once we cross over that 15%+ bullshit.
Tokyosmash! is offline
Old 07-09-2019, 05:33 AM
816d16 owes me money!
usdm420's Avatar
I'd love it if E85 was available locally. I'm about to buy a 55-gal drum with a pump for the garage.
usdm420 is online now
Old 07-09-2019, 11:44 AM
HNIC
vtecvoodoo's Avatar
I run E85 in my GT3. Cheap and runs cool.
vtecvoodoo is online now
Old 07-09-2019, 12:04 PM
B20 Bhai M.B.B.S
b20sedan's Avatar
I picked up nearly 100whp by going from 91 octane to E85, I also lifted my heads with that whp jump and put my local tow truck drivers kid through community college though
b20sedan is offline
Old 07-09-2019, 12:12 PM
Moderator
TheShodan's Avatar
Well..
- you're basically running sugar through your fuel system
- has fewer BTUs of energy combusted than 93 octane. (Which is why you need such larger fuel lines and injectors compared to.VP109 or methanol
-may be cheap but you're refueling more than grandpa goes to the bathroom on a day
- requires significant changes to fuel lines since you're not running petroleum (see 1st point)
- if you store the car for extended periods, you need to put 91-93 octane back in, or start issues occur
-doesn't work well with high zinc content oils like Brad Penn (turns into sludge quickly).
-flex fuel sensors and such make it one more gauge to read.
Etc,etc,etc...
Old 07-09-2019, 12:13 PM
HNIC
vtecvoodoo's Avatar
in a POS subaru or mitsu? =D
Old 07-09-2019, 12:17 PM
B20 Bhai M.B.B.S
b20sedan's Avatar
Itís a single turbo VQ, L19ís sorted out the head lift, making a happy 700whp now
b20sedan is offline
Old 07-09-2019, 12:46 PM
usdm420's Avatar
It's only available down in Phoenix area and even then I hear most of it tests on the shitty side (more like E54).
BUTTTT a buddy's shop up near me is now an authorized VP dealer. I also got the number to a shop down in Phx that can get me T85 in drums too. Since I don't daily it, 55 gal drum of it might make sense.
Old 07-09-2019, 01:01 PM
ky13's Avatar
E85 at the Sheetz down the street.
ky13 is offline
Old 07-09-2019, 02:17 PM
HT White Ops
rochesterricer's Avatar
Tuners seem to say you get all the benefits at anything above 50% ethanol.
rochesterricer is offline
Old 07-09-2019, 02:21 PM
B20 Bhai M.B.B.S
b20sedan's Avatar
Yeah, pretty much... E54 is maybe a 2-3% drop in power potential from E85
I've been diluting my E85 down to 60-65% E as my injectors are completely maxed out
b20sedan is offline
Old 07-09-2019, 02:23 PM
Yea most tuners only tune for an e60 mix.
Not sure about this platform, but Subaru has a flex fuel kit that efficiently measures the level of ethanol in your tank along with your regular gas to make a mix. You can pick up considerable amount of WHP/TQ with stock components with a flex fuel kit.
There is e85 at Newark airport, but it would be such a pain to go back and forth, and I have no place to put a large gallon drum, which would be the only way I would use e85. IF I had the space for one, I would definitely run e85. It prevents detonation substantially.
vLad11591 is offline
Old 07-09-2019, 02:44 PM
-Intl Steve Krew
Caoboy's Avatar
T minus 10....9....
Caoboy is offline
Old 07-09-2019, 04:30 PM
ky13's Avatar
I prefer to tune systems that can adapt flex sensors (like AEM), so the maps are blended as a function of ethanol content. Back in Va (Manassas) E85 was consistently E85-90. The station in Ashburn was consistently E70+-. I haven't filled up since moving to WVa, so I'm not sure how consistent the local blend is.
ky13 is offline
Old 07-09-2019, 04:43 PM
"Haters Gonna Hate"
FrostyDC4's Avatar
Stock tune?
FrostyDC4 is online now
Old 07-09-2019, 05:32 PM
Tell that to a rancher or farmer that has already spent $200,000 on a number of pieces of equipment....that has to work like hell to make ends meet. Spending more on newer equipment or modification (and can you modify a harvester?), will end some of the independents and family owned outfits. I live near several small farms and ranches.
....not to mention that I'll spend up to another 7-8k to keep my car...with a K swap. It's worth it to me, but I'd rather run my B18a1 for several more years. Only 180k miles. I guess I'll have to learn more about tuning and such than I thought I'd have to.
Old 07-10-2019, 06:36 AM
HNIC
vtecvoodoo's Avatar
Originally Posted by FrostyDC4 View Post
Stock tune?
No, tuned for e85.
Old 07-10-2019, 07:07 AM
AZ_CIVIC's Avatar
E85 is good stuff if you make power and street drive. I did a write up back in the day and tracked my MPG loss going from 91oct to E85 and my turbo car went from like 31mpg to about 26mpg. Back when I started using E85 though it was about a dollar cheaper than 91 so it all balanced itself out. I never had issues with the fuel eating anything.
AZ_CIVIC is online now
Old 07-11-2019, 08:46 PM
DaIll1's Avatar
Originally Posted by TheShodan View Post
Well..
Etc,etc,etc...
My Kawasaki F7 loved it blended with castor oil, but it needed a huge fuel petcock and jets.
DaIll1 is offline
Mufasa
51
08-12-2011 06:41 PM
MySelfAffliction
85
05-06-2009 07:46 AM
flight50
08-17-2005 06:27 AM
mike93eh
13
04-14-2004 04:14 PM
sauceman
14
04-07-2004 05:37 AM
Quick Reply: There are E85 stations popping up in my area.. why is that lately?
