space heater question
Old 11-05-2011, 11:13 AM
tw1tch's Avatar
Default space heater question
I picked up a space heater the other day. It says it's 1500 watts. I was told that it costs 15 cents per hour to run it. My question is, does it use the same 1500 watts no matter what temperature I select? It goes 65-70-75-80-85. Just curious thanks.
tw1tch is offline
Old 11-05-2011, 11:29 AM
__oversea's Avatar
Default Re: space heater question
It works like home heating system, unlike old style where you set the temperature and it generate that heat continuously.
__oversea is offline
tw1tch's Avatar
so does it use 1500 watts at both 70 and 80 degree settings?
tw1tch is offline
Old 11-05-2011, 11:37 AM
eight equals equals equals D
Tim2179's Avatar
Depends on the temperature in the room. It heats until it reaches the desired temp, and then shuts off.
Tim2179 is online now
Old 11-05-2011, 11:41 AM
1995Ex_Sedan's Avatar
If there was a lo-med-hi setting then it would only use the max on hi. However, this one seems to have a t-stat so..yeah, full blast until it reaches the set temp.
1995Ex_Sedan is offline
Old 11-05-2011, 11:44 AM
tw1tch's Avatar
It stays on for 4-8-12 hours. Even once it reaches the temp you set, it stays on. The electric company says it costs about 15 cents an hour, but I am just curious if he mis-understood me
tw1tch is offline
Old 11-05-2011, 11:56 AM
__oversea's Avatar
I believe it stays on at low/idle temperature, then ones temperature drops it gives full potential.
So it is on all the time, just not full power like I said.
Email or call manufacture if you really want to know.
Old 11-05-2011, 12:09 PM
Tim2179's Avatar
Will the cost of use change the way you use it?
Old 11-05-2011, 02:37 PM
yankkesrule's Avatar
Is it true that if you don't use it, you lose it?
yankkesrule is offline
Old 11-05-2011, 05:37 PM
fastcrxsi90's Avatar
Location: the asshole of america..., upstate new york, USA
yes, unless its a 2 stage heater (1.5kW & .75kW).
it should cycle on/off to maintain the setpoint temperature...even it it has a timer on it too.
1.5kW * $0.10/kWh = $0.15/hr...so yeah, that makes sense. But remember that it will cycle on/off within that hour...unless you have a very large room or the windows open.
fastcrxsi90 is offline
Old 11-07-2011, 04:52 PM
blackeg's Avatar
yeah 15 cents sounds about right if you are paying 10 cents per kilowatt hour. i think im paying about 9 cents per kilowatt hour and have 2 of those little 1500w heaters. i keep my house thermostat on about 60 (oil heat) and then use the 2 heaters in the living room or bathroom. its cheaper than using oil straight out.
personally i wouldnt leave them on all night, when im not home or trust the thermostat to hold properly. i keep mine on only if im home and awake
blackeg is offline
Old 11-07-2011, 05:09 PM
98cdmej6's Avatar
still no space haters?????
98cdmej6 is offline
