Official Home Improvement
Old 11-20-2015, 05:54 AM
  #1501
Bloody Beaver
.Beaver's Avatar
Default Re: Official Home Improvement
Originally Posted by rota92 View Post
Mrs.Blue, is that you?!?!
.Beaver is online now
Old 11-20-2015, 08:49 AM
  #1502
MidnightS14's Avatar
Someone told me that I have this sink drain roughed in wrong. He said it should be like this...
Instead of how it is currently, see attached. I fail to see how it would make a difference.
MidnightS14 is offline
Old 11-20-2015, 09:07 AM
  #1503
-Intl Steve Krew
Caoboy's Avatar
Is the pipe in his picture threaded?
Caoboy is offline
Old 11-20-2015, 09:15 AM
  #1504
something gnarly
5SpdH22's Avatar
i can't find the difference....
5SpdH22 is offline
Old 11-20-2015, 09:28 AM
  #1505
Drunk Wagon Pilot
Pinja's Avatar
Pipe up top is wider than the bottom pipe? That's the only issue I can see
Pinja is offline
Old 11-20-2015, 09:38 AM
  #1506
aka DaZman69!
usually the vertical stack does not line up with the sink because the stack fits better in X location and the sink fits better in Y location. You also don't want a horizontal run outside the wall because it will impede on vanity placement just be stupid to do when you have a wall open.
I'm not a plumber, but I'm close, I'm giving it an 80% chance it's fine and that the person who told you that has just never seen it done that way.
sflkgjsfndgn is offline
Old 11-20-2015, 09:42 AM
  #1507
something gnarly
5SpdH22's Avatar
ohh, talking about the horizontal run. I've heard of a max length for that, but never a minimum.
I'd think ideally you'd want it how you have it to save on pipe (makes a difference in high rise residential but not here), but that probably doesn't happen often like sflkgjsfndgn said.
5SpdH22 is offline
Old 11-20-2015, 10:07 AM
  #1508
That's the vent, so it doesn't really matter.
I was thinking the same thing, he's never seen it that way. I found similar pics online searching "sink plumbing sanitary tee". Read the trap arm has to be min length of 2d, so 3" in my case. Should be easily achievable before the p-trap.
This weekend I being soldering supply lines.
Old 11-20-2015, 10:22 AM
  #1509
aka DaZman69!
soldering? Pex it, copper is just a waste of time and money.
Not sure what you're tapping into, but if it's for a bath sink and you don't have low pressure, run 3/8th's pex back to the water heater for the hot. Hot water will come out in seconds. Bath sinks always take forever to spit out hot water since they are low flow and usually have to dispense the water in a 3/4" trunk line to the bathroom.
Old 11-20-2015, 10:29 AM
  #1510
Tapping into 1/2" copper. Wish that was an easy option, but unfortunately the hw heater is in a storage room attached to the house by a carport. The supply lines run under the carport slab, then come back up into the crawlspace.
Old 11-27-2015, 04:38 PM
  #1511
Steve at Heart
Bently_Coop's Avatar
Talk me out of this ladder.
Guy at work says they are fairly heavy to move around, I am more into the sale price and adaptability for different situations, plus I wont need multiples.
Looks like it only weighs 40lbs though.
Shop Werner 17-ft Aluminum 300-lb Telescoping Type Ia Multi-Position Ladder at Lowes.com
Werner 17 ft. Aluminum Telescoping Multi-Position Ladder with 300 lb. Load Capacity Type IA Duty Rating-MT-17 - The Home Depot
Bently_Coop is offline
Old 11-27-2015, 07:28 PM
  #1512
put title here
b_ack51's Avatar
Going full potato on this home automation. Now I'm just playing around and learning about stuff so that next place will be legit.
Added SmartThings hub and front door lock.
b_ack51 is offline
Old 11-28-2015, 09:56 AM
  #1513
aka DaZman69!
https://www.youtube.com/watch?v=ePLdhPjlaog
I have the bigger version of that
I do not like it. It's too heavy for what it does, it's also a pain to extend to max length.
17ft is not very high. I'd rather have a normal extension ladder.
The thing its good for is working over a staircase as you can make one side short and one side long. Other than that, it looks more handy than it is.
Old 11-28-2015, 01:53 PM
  #1514
Steve at Heart
OK, didn't realize until after that a normal ladder is about 22lbs. Going to take a look in the store this week and see whats up.
Old 11-30-2015, 07:03 PM
  #1515
Skelly's Avatar
Just purchased 42 four foot t8 LED bulbs for my garage. Garage is roughly 25'x40'. I literally have the worst garage lighting ever. However, that is about to change.
Skelly is offline
Old 11-30-2015, 07:05 PM
  #1516
Bloody Beaver
.Beaver's Avatar
I need to get on that. Will need sunglasses doe.
Old 11-30-2015, 07:10 PM
  #1517
H-T White Ops
Frozen E's Avatar
Holy ****!!!
Frozen E is offline
Old 11-30-2015, 07:29 PM
  #1518
Skelly's Avatar
Originally Posted by solbrothers View Post
led t8 technology isn't good enough yet for me to jump into. and prices are retarded
@skelly how much you pay per bulb? What wattage are teh bulb? lumens?
I paid 9.75 per bulb. I went with the recommendations of a dude on garage journal. See at The Best Light Fixture Ever! - The Garage Journal Board. First post.
Bulbs I purchased.
James Industry BT8P18W4FT 18 Watt 4 Foot LED Plug and Play Ballast Compatible T8 Linear Tube Lamp Plastic Housing
I referred someone at work at got $1,500 this month so i said *** it and got my garage redo moving.
Cant insulate the attic until I install lighting. Cant put down epoxy flooring down until I can see what the *** I'm doing.
Skelly is offline
Old 11-30-2015, 09:20 PM
  #1519
aka DaZman69!
Eh, depends what you're current stuff is.
Not smart - have a garage full of t8's and replace them with led
Smart - have a garage with nothing or minimal lighting and install led instead of t8
Old 11-30-2015, 09:28 PM
  #1520
aka DaZman69!
Bulbs I purchased.
Old 11-30-2015, 09:56 PM
  #1521
H-T White Ops
Frozen E's Avatar
In the grow lamp fixtures I use I have four 54 watt High Output T5 bulbs in each one and they're INSANELY bright. They'd easily outshine any T8 bulb out there. And they're pretty damn cheap too. You can get a pack of 15 for about $80 at Home Depot.
Philips 46 in. T5 54-Watt Cool White (4100K) High Output Linear Fluorescent Light Bulb (15-Pack)-414193 - The Home Depot
Frozen E is offline
Old 11-30-2015, 10:00 PM
  #1522
Steve at Heart
This is where I am at with other things as well, might as well wait until the price drops or the bulbs go out.
Old 11-30-2015, 10:17 PM
  #1523
They let me pick
mrdeadman's Avatar
But do they start at below zero?
mrdeadman is offline
Old 11-30-2015, 10:21 PM
  #1524
H-T White Ops
Frozen E's Avatar
Not sure. They fire up in the mid to low 20s.
Frozen E is offline
Old 11-30-2015, 11:30 PM
  #1525
aka DaZman69!
what people are saying is that they emit too much light from a single source. Which is uncomfortable on the eyes. It's better to disperse the light with more and less powerful light fixtures.
T5ho is not ideal for low ceiling heights
Quick Reply: Official Home Improvement
